Pansat 3500sd or 2700
Username: The_don
i have the option of buyin either a pansat 2700 or 3500 but i want to know which one is newer and better
Username: Leew
Ketchikan, ALASKA
Post Number: 234
3500 is newer=better.
Username: Lklives
Post Number: 1235
3500SD is newer and has the card to use in lieu of cable...it has BOTH cable and card..its better
Username: The_don
i bought the 3500sd, brand new for 180,
i have a question though, wats the point of a card, wats it do, and wats the cable. sry i'm new in this
Username: Mzakcat
Post Number: 12
well the don WHY DID YOU BUY the 3500sd wats the reason?????
Username: The_don
to get TV, lol
i'm also wondering if there is a step by step posted somewhere for newbies, to program it or w/e for ppv and all that like dishnetwork, i never used fta, its my first experience, but i used dtv, and dishnet
Username: Sva
I've read a couple articles talking about putting dumbie satellites in the sat list, is this always necessary or necessary on a 3500SD?
Username: Leew
Ketchikan, ALASKA
Post Number: 351
How to set up...for newbies,use this link :
http://forums.dss*tester.com/vbb/showthread.php?t=39491
Username: Leew
Ketchikan, ALASKA
Post Number: 352
dont forget ,to remove {*} in d s s t e s t e r
Username: Leew
Ketchikan, ALASKA
Post Number: 353
For 50 CAL.........
I got 3500sd,and I never renamed or put dumm..sat. just flashed with Bin, blind scan and wait till autoroll getting the key. That is all.
Username: Sva
Thanks M W Lee, I just wanted to clarify.
