Need Help with T5-KU Sat.
Username: Rostam
Post Number: 8
I am not able to get Setanta sport, Euro News, RTR sport and few others stattions (rest is fine)on T5-KU sat (international).
I checked the TP , simbol rate and other details with LyngSat. They are all OK.I should tell when I bring up Setanta Sport for example; in the bottom of the screen signal reception indicator shows activity, but the screen goes into Scramble Bad signal mode. Any ideas...
To get all international channels unscrambled do I need to enter a new "key" or do I need a Bin file?
Thank you,
Username: Leew
Ketchikan, ALASKA
Post Number: 140
you cannot get RtR sport , you have to wait.
eti pidari pereshli na druguu kodirovku, ili nexuya ne pokazivaut voobshe koroche tolkom nikto neznaet. mi vse ghdem
KGB
Thanks Man. I went crazy about globecast.Now I see, what is going on.
Username: Rostam
Post Number: 9
OK, Thanks.
what about Setanta sport or Euro News. I bring up Setanta Sport for example; in the bottom of the screen signal reception indicator shows activity, but the screen goes into Scramble Bad signal mode. Any ideas...
Username: Leew
Ketchikan, ALASKA
Post Number: 141
Well, you need a new bin, but there is no new bin special for globecast N2, I did try to chahged key in cas system N2 for globecast ..nothing , no work at all ,even I cannot change provider ID, it dosen hold it, all ways come back to FFFFFFF.... so thats why I think it's BIN file. So we have to wait
Username: Leew
Ketchikan, ALASKA
Post Number: 142
But, I think ,I got Euro News, I have to check it out, when I get home I'll do it, then I post it.
Username: Rostam
Post Number: 10
Mike Lee,
Cool thanks, I take it you don't get setanta either. It was ok until Monday Morning PST. Do let me know if you still get Euro news.
Do you know where I can read about the bins required for globecast old or new files.
Username: Leew
Ketchikan, ALASKA
Post Number: 143
No , but I looking too,if I find I will post it. Many people looking for this info.
Username: Leew
Ketchikan, ALASKA
Post Number: 144
about EuroNews I let you know in 5 hours.
Username: Rostam
Post Number: 11
Mike,
Is globecast provider for T5-KU sat (international).
Username: Leew
Ketchikan, ALASKA
Post Number: 145
T-5 use it couple providers. most of it arabic. T-5 it's realy international "bird"
Username: Leew
Ketchikan, ALASKA
Post Number: 146
O, I checked Setanta sport, it's coded by Irdeto system. I never see Irdeto Key.
Username: Geeker
Post Number: 73
I have setanta and euronews working fine. RTR sport works only on saturdays and sundays.
Mike, there are two encryptions for setanta. One is Irdeto encrypted and it's not working, the other is n2 encrypted and is working fine.
Username: Leew
Ketchikan, ALASKA
Post Number: 147
I tell you,aint check since RTR Sport went out.that is why I promise to check it today .
Username: Rostam
Post Number: 12
Mike,
Incase you got both setanta and Euro, please check your current keys and send me so I acn compare.
Username: Rostam
Post Number: 13
geek,
can you share your keys
Username: Leew
Ketchikan, ALASKA
Post Number: 148
Ok
Username: Rostam
Post Number: 14
Mike,
I have Pansat 2700a. What is your box please?
Username: Rostam
Post Number: 16
Mike,
I have Pansat 2700a box. What is yours?
Username: Leew
Ketchikan, ALASKA
Post Number: 149
my 3500s pansat
Username: Leew
Ketchikan, ALASKA
Post Number: 150
and I wanna buy second one, dreambox 7050.
Username: Rostam
Post Number: 17
How to enter keys: Is this where you put the keys we are talking about?
Press menu button on your remote:
#1 Go to parental control...
#2 Go down to "second pin" option & enter 0000
#3 Then go to nagravision and select it by pressing ok button on your remote...
#4 In Nagravision window you should be in the box that is Entitled "Provider ID"...scroll to the right (press right arrow button on remote) until it switches to globecast N2
Right....
Username: Rostam
Post Number: 18
Mike,
Above question is for you.
Username: Leew
Ketchikan, ALASKA
Post Number: 151
that is right. only.. until it switches to globecast N2 ,you have to use provider ID by digits..let say DN 0101 ,Bev 0901 Globe C101.But this is my problem,I cannot do it in Nagra2 with Globecast ID nothing. (only Bev and DN). In Nagra1 no problem.
Username: Leew
Ketchikan, ALASKA
Post Number: 152
So, I guess what is Globecast coded in Nagra1 I can watch without problem.
Username: Leew
Ketchikan, ALASKA
Post Number: 153
Ones I opened bin file, there is a lot digit thats all, but how to write it or move it ,I have no idea.
Username: Rostam
Post Number: 19
Is the "Globe C101" is a valid ID?
Username: Stormcat
Which Bin has the globecast N2 selection 256t doesn't?
Username: Leew
Ketchikan, ALASKA
Post Number: 157
Ok, by me Globecast Id is C001 , in Nagra1.
SetantaSport (bad or Scrambled)
Username: Leew
Ketchikan, ALASKA
Post Number: 158
O I got SetantaSport in Irdeto system too..Upload
Username: Leew
Ketchikan, ALASKA
Post Number: 159
Ray Rad ,tell me ,how much channels you got on T-5. I got total 180.
Username: Stormcat
This channel was opened today for the Ireland v Sweden International Friendly normally it is scrambled?
What about the other Setanta channel further down the T5 channel list?
Username: Stormcat
Geek Geek what is you setup?
Username: Rostam
Post Number: 20
I get about 173, but some are scramb... Where did you get Irdeto. I don't see it on mine only T-5/KU
Username: Leew
Ketchikan, ALASKA
Post Number: 165
It's came with Bin file
Username: Leew
Ketchikan, ALASKA
Post Number: 166
about Euronews,I got from Nimiq 2.
Username: Leew
Ketchikan, ALASKA
Post Number: 167
Username: Rostam
Post Number: 21
Mike,
Where can I get the bin files to get setanta and euro news please? salamreza1@yahoo.c*m
Username: Leew
Ketchikan, ALASKA
Post Number: 175
I got Bin here: http://www.dsstester.c*om/files.php?cat=14
(you have to remove star in "com").
But my receiver is pansat 3500s ..yours is 2700a. Bin files no the same. So you have to pick up right one, for you!!!
Username: Geeker
Post Number: 74
sorry guys I just got back to my computer. As I said there are two sets of setanta one is Irdeto and the other is nagra. The nagra one is working fine. I will tell you the keys once I finish scanning my sats agains. By the way if you have a pansat 2700A, there is a new bin that works for
globcast N2 that came out just today.
Username: Rostam
Post Number: 22
Geek,
What is the bin number?
Username: Rostam
Post Number: 23
Mike,
Do you know...
I just got a new Pansat 2700a. With What Bins do I need to flash the reciver inorder to get all international programs? What Bins do I need for Dish Networks.
Thanks
aznknightz17
hey guys,
where can i get T5-Ku channel list?
Username: Rostam
Post Number: 24
Sat is Linear. Known as Telstar 5 or T5. Located at 97 West
Basically, Globecast is a provider of foreign language sat service:
You will need a larger dish for T5. Usually 30+ inches, depending on location.
I have posted a sat signal map and a chart with recommended dish sizes beside it.
The bin allows you to receive Ku band, by using a Linear LNB.
The larger *choice, ParaTodos, Phase III, etc dishes may be modified to work, depending on where you are located. I would think that a DN SuperDish might also be OK since that too is made to receive signal with a Linear LNB..
D300, D500 and B3v dishes are all too small for a consistent signal.
Again, the larger the dish, the better.
It's probably the most sensitive sat to lock onto. It has a very narrow beam so proper preparation with accurate sat settings, plumb masts and methodical patience is required when setting it up.
The LNB must be skewed in it's mount in order to obtain maximum signal quality.
Signal quality may be as low as 25 or as hgh as 80 and you'll still be able to get signal. Not like in circular LNB's
Irdeto 2 will soon follow!!
http://www.future-fta.info/forum/showthread.php?t=17328
Channel list here:
http://www*future-fta.info/forum/sho...1&postcount=10
aznknightz17
erm...channel list link invalid...i removed the * also...
Username: Leew
Ketchikan, ALASKA
Post Number: 211
The administrator may have required you to register before you can view this page. That's why you cannot go in.
Username: Rostam
Post Number: 25
Mike,
What BINS do you need for new Panasat 2700?
Is there a new Bin out for TK5
Username: Rostam
Post Number: 26
Mike,
I mean what bins do I need?
Username: Leew
Ketchikan, ALASKA
Post Number: 216
Wait,I go check for you....
Username: Leew
Ketchikan, ALASKA
Post Number: 217
Im back with good news for you.You have to flash pansat 2700a to get T-5 with X-87BL_060303_145_api bin file.(I hope yours pansat is not clone).
Username: Rostam
Post Number: 27
How would I know if my Pansat is clone? email me the bin please salamreza1@yahoo*com
Username: Leew
Ketchikan, ALASKA
Post Number: 218
Do you flashed before,if yes how many times and what bins you used ?
Username: Geeker
Post Number: 75
Ray the bin is the 145. you can find it at any dss site. Also there is no clone on the 2700A, only the 2500A have clones.
plutoman
hi mike ,
i am new here. i have a pansat 2500a loaded with 271t bin. would i be able to get T5 (97W) channels with this bin on my pansat. please answer.
thanks.
pluto.
Username: Leew
Ketchikan, ALASKA
Post Number: 219
For geek geek . You want I send you web, where you can get pansat 2700A clone...
Username: Geeker
Post Number: 76
plutoman you need 272. Make sure your receiver is not a clone before loading.
Username: Leew
Ketchikan, ALASKA
Post Number: 220
X-85BL_060304_272_au_api(N)
Username: Geeker
Post Number: 77
Has anyone been able to get InXtc channel on T5. If yes, then what encryption is it, and with what file.
plutoman
hi geek geek and mike,
many thanks for the quick response.
plutoman.
Username: Rostam
Post Number: 29
Mike,
No, I have not flash before, but I have read enough to know how. My reciever has Echo7, Echo 8.6 & T5 files on it.
When I flash Bin145 do I need to know anything.......
Thanks
Username: Rostam
Post Number: 31
Geek,
Thanks Dud
Not So Far
@ Mike.....I will give U 99 dollars....CDN
for Pansat 2700a....With switch and cable...
How many do U have Mike....Your friend from
not so far away.
aznknightz17
Hey,
I want to get Chinese channels movies on T5-Ku but i cant...i did the blind scan and no chinese movie showed up....any idea?
Username: Rostam
Post Number: 32
Mike,
Can you send me pansat bible please? salamreza1@yahoo.com
Username: Geeker
Post Number: 78
aznknightz17 you have to be very specific so we can help you. Specify the receiver, the bin, the location, the setting.
Ray I know you asked mike, but I will go ahead and unswer anyway. Once you install 145 bin, just connect your receiver back, make sure all the setting are correct according to your hardware. Push default key under CAS system, blind scan or sat scan and you are ready to go.
Username: Leew
Ketchikan, ALASKA
Post Number: 259
What, you dont get it,I did , 5 hours ago.
o men Upload
Username: Leew
Ketchikan, ALASKA
Post Number: 262
@Ray Rad ,I sended over what you ask,everything is halyal don't worry .Upload
Username: Aznknightz17
@geek geek, i got pansat 3500sd/bin 142/live in atlanta,ga. Currently got 110,119,T5-Ku. In my T5, i am unable to watch chinese channels among others. I did blind scan and some channels i can watch and some i can not. Why so? Does DN have Jade Channel package or its exclusive to Dtv only?
Username: Geeker
Post Number: 79
@aznknighz17, the 142 bin is the wright bin, and if you can see some channels and others you can'ton T5, then there are two possibilities of what the problem might be. First the channel or channels you are trying to watch maybe are Irdeto encrypted, and for that you need to visit lyngsat and check the encryption of the channels you are trying to watch, as Irdeto is not hacked yet. Second if the channels you are trying to watch are N2 encrypted then check and see if the TP where the channels you are trying to watch has signal. You have to know that it's very hard to have good signal on TPs of T5.
Username: Plutoman
hi mike
i loaded my pansat 2500 with 272_au bin.is this good enough to get T5 channels. I saw another 272 bin named 272T2_GC. What is the difference between these two. Do ineed to load the 272T2_GC to get T5(Globecast).
thanks,
plutoman.
Username: Plutoman
answer me mikie!
pluto.
