gurneev Unregistered guest | Hi I programmed a reciever but now that file is an old bin and I now want to flash it with a new bin file. wat do i do? |
Silver Member Username: LklivesPost Number: 870 Registered: Jan-06 | Same thing U did the first time..and its explained here at least 5000x.. |
189 Unregistered guest | what kind of receiver |
Nelson R Unregistered guest | Hi i have a pansat 2700a and it just went down for the first time i've followed all the steps to get to nagravision 2 but it seems like the receiver does not have that option can anyone tell me how i could get nagravision 2 installed on my receiver. |
gurneev Unregistered guest | thanx LK and I have a pansat 2700-N2 but the one i was talking about is 2700A it is a friends I programmed |
Silver Member Username: LklivesPost Number: 874 Registered: Jan-06 | read this.. https://www.ecoustics.com/electronics/forum/home-video/202045.html |
Nelson R Unregistered guest | i don't have the attached file you are talking about . anyway if i upgrade to any new bin will i have nagravision 2 |
Silver Member Username: LklivesPost Number: 877 Registered: Jan-06 | yes..if U do a scan first , so U can get to "parental controls" first, if U need to change DN keys..unless u use an autoroll bin |
Nelson R Unregistered guest | where can i get autoroll bin for pansat 2700. does it need any internal mod or is it just a bin upgrade. also LK can u give me ur opinion on autoroll do u think its better than manual input |
New member Username: C71ssPost Number: 5 Registered: Feb-06 | hello can anyone help .i have a viewsat 2000 plt and downloaded files flashed said ok but went yo install dish and cant get pin# . IT CHANGEd IN THE DOWN LOAD HOW CAN I GET it please 1 nuub |
Silver Member Username: LklivesPost Number: 880 Registered: Jan-06 | nelson..any DSS site has the latest autoroll bin for almost every reciver..U want the 144 bin..ye, autoroll is the best...its just different , an Upgrade as U say...its not any internal mod to the receiver..its just a different bin with an autoroll code so new keys will be received and put into the receiver data bank.. dsstester.c om dsscentral.n et |
Nelson R Unregistered guest | thanks LK we've been a lot of help. just one last thing, So all i need to do is upgrade my receiver to bin 144 and the autoroll feature will automaticaly be used. |
Silver Member Username: LklivesPost Number: 882 Registered: Jan-06 | yes |
Nelson R Unregistered guest | ok thankyou so much LK you've been the best help ever. I swear this is the last qustion in GTRom loader what file type do i select when upgrading the bin 144. thank you |
Silver Member Username: LklivesPost Number: 884 Registered: Jan-06 | 5. Click the App File only button, browser and select the "latest update" file,example X-87BL_050901_114_api then click the Open button |
Nelson R Unregistered guest | hey LK i've red some stuff about the autoroll bin and some say that you must click set default keys is this true. And what else do i need to know before i install bin 144. |
Nelson R Unregistered guest | can someone please answer my question please befor i upgrade to bin 144. in new and this is my first time. some instructions would be nice on how to get autoroll working. |
Anonymous | were are you live,I can stop by and help you out...Dont be afraid ,I am nice ,young very pretty girl... |
Silver Member Username: LklivesPost Number: 896 Registered: Jan-06 | nelson...yes set deafult key...menu- parental control-2nd pin 0000- scroll down to "set default key" (screeen option)-enter-emu ON -save and exit |
Nelson R Unregistered guest | LK is that do i set default keys before or after |
Silver Member Username: LklivesPost Number: 905 Registered: Jan-06 | after U load the 144 bin |
Nelson R Unregistered guest | hey LK i've read that Dish network is sending fake packets to through off the autoroll feature. they suggest that u turn off autoroll and input keys manually. can u please tell me how autoroll can be turned off |
Silver Member Username: LklivesPost Number: 913 Registered: Jan-06 | thats old news, before 144 was released...and the 144 bin was released and coded to stop that..so just do as I recommeded and keep reading CURRENT things.. |
Nelson R Unregistered guest | ok thank you you soo much LK your doing a great job at helping me out |
Nelson R Unregistered guest | LK i have a friend whos satellite just went down and he had put the bin 144 about a week ago. he says that the autoroll function isn't working automatically. is their something extra u have to do such as a scan or something else. or does the keys get entered atomatically and the satellite is back and running thanks again |
New member Username: Mdl97Post Number: 3 Registered: Jan-06 | does anybody know if dish will be carrying the vargas mosley fight.on my box on the ppv guide it says my next scheduled ppv is ufc -usa vs canada.i was wondering if anybody has any info. |
New member Username: Mdl97Post Number: 4 Registered: Jan-06 | what can i do about bad or scrambled channels?i put in the new keys a while back but i get some channels that are bad or scrambled.some of the adult channels and some other ones are not coming in at all.i have the skyview 500 box.thanks any info will help. |
Silver Member Username: LklivesPost Number: 916 Registered: Jan-06 | ask your friend.. |
Nelson R Unregistered guest | hey LK my sat went down i have the new bin which you told me to get which is bin 144 do i have to click on "set default keys" for the receiver to use the autoroll feature and input keys automatically thanks |
New member Username: Jlg8Post Number: 1 Registered: Feb-06 | help LK i have a pansat 2500a and i'm new at this. the guy who use to reprogram my set is being a jerk and won't reflash my set can you e-mail me the site,bin and directions on how to do it myself. i've been down since about 3wks. thanks |
Joe Da Silva Unregistered guest | hey LK my sat went down i have the new bin which is bin 144 do i have to click on "set default keys" for the receiver to use the autoroll feature and input keys automatically or something else thanks |
Anonymous | Take big hammer and bang it by the left side of yours receiver. |
New member Username: Dgil53Post Number: 1 Registered: Mar-06 | i am new to this. i have always been using a fortec ultra but would now like to go into the big leagues and be able to unlock all the channels. i have a dishpro 311 receiver and a regular dish. please help me program this. i would like to know step by step what to do, how to do it and what i need to do it. would really appreciate the help and would consider donating a small fee to you for your help. please email me d_gil_53@hotmail.com |
Gold Member Username: LklivesPost Number: 1174 Registered: Jan-06 | U willneed to go to another DSS site...this here is basically FTA receivers..go to |
