I have a dish pro and a pansat 2400. I recently decided to sell my 2400 and upgrade, the guy I sold my box too has a superdish I was told this wouldnt be a problem, but when he hooked up it would not work. I checked the keys in the box, it was running at my house, but they had changed, we tried to put new keys in but it would not save them. I took the box home and re-inputed the keys and it works fine. Is there some reason why the box would not save the keys, if he has a superdish?? Any one heard of this?
Superdish and receivers have nothing in common...the dish does not hinder the receiver or the keys...
what is a pansat 2400?...never heard of it....must be a dinosaur or non existent..
MCBRYANT
maybe i have a pansat 2500 dunno, but the keys would not save at his house, All we could figure was because i had a dish pro and he had a super dish, Could their be different switches or something?? Any help would be appreciated. Gonna try to reflash see what happens.
MCBRYANT
LNB's and type dish have nothing to do with saving keys...its the reciver and the operator that it!..if they don't save, then the operator did something wrong!..nothing affects saving the keys..
MCBRYANT
switches do have something to do with reviever. some switches like sw21 wont work with some dishes. Not the dish, the switches, external ones.
switches have NOTHING to do with the keys being saved!
Is there some reason why the box would not save the keys?...operator error...NON SAVED keys has nothing to do with the LNB's, the switches, the dish type or ANY other hardware....admit it...U screwed up...its no biggie, since U got it right the 2nd time..
BTW...Are U talking Dishnet or Bev keys?...they are put in the same way, except for the provider ID is different..
#3 Then go to nagravision and select it by pressing ok button on your remote...
#4 In Nagravision window you should be in the box that is Entitled "Provider ID"...scroll to the right (press right arrow button on remote) until it switches to Dishnetwork (00 01)
#5 Now In Nagravision window go down (press down arrow on remote) to the box that contains "00" entitled "Key Number"
#6 While in the box (highlighted "Key Number") that contains "00", scroll to the right until you see nagravision 2 at the top left of your screen
#7 While in Nagravision2 you should still be in "Key Number" box and the number in that same box should be "00"...this is for Key 00
#8 Scroll down (press down arrow on remote) to key data and enter the new supplied key for 00 (within this site is the key change for Nagravision2)..take note on how to enter letters in the lower portion of the screen (ex. letter E=FAV button on remote)
#9 Once key is edited select OK button on your remote (OK-STORE confirmation blinks twice in lower right of screen)
#10 go back to the "00" box and move one click to the right which should take you to "01"..this is to edit the "01" key
#11 Follow Steps 8 & 9 above (this time enter key data for key 01 instead of 00)
#12 Click exit and click ok or yes to save changes then exit all the way out and you should be watching tv
Note...For /Bell keys at step #4, "Provider ID" is 09 01
