61.5 W
ananymouse
is 18" dish is good for getting 61.5 bird.
i am in torronto. what is the LO frequency.
Satellite Driver
11250 if Im not mistaken
Drunk Buckeye
I"ll second the 11250 LO freq.
I hear a lot of you Canadians have a hard with 61.5 But you aren't that far up there. Hey you might want to try the 129 location also. Everything on there is the same as 61.5 from what I can tell.
Pepe Smith
for better reception and easy hunting for bird 61.5 use 30-36 inches dish(3ft)
ananymouse
thanks very much guys/ gals for your input. much appreciated.
