2 DISH HELP
Username: Barass
ok this is fooked i have 2 dishs 1 is 110 and 2nd is 119 my problem is im having problems with 110 ? none of my channels are working but both the level and quality are good ? screen is black ? ..... so i did a scan of channels and only a few now come in that i scanned ? rest are black but signals are good ? could it be a fooked Diseqc or is it in my Antenna setup ?
LNB type Standard
LNB Local-Freq 11250
22kHz 0ff <--- tried on no change
Diseqc #1
LNB Power ON
TP 12224 V 20.000
Positioner Disable
Sat Scan FTA
i have tried all the Diseqcs and still wont work
Plz help would like to watch PPV Movies !
Username: Barass
ooops forgot to say its a Fortec Star
Username: Thehitch
Fla.
Post Number: 317
Hey john smith try ALL chan scan not FTA.
changing nicks
TIM,DESPERATE, YOU ARE A SOFTWARE SELLER. SELL THE SOLUTION LIKE THE CD'S YOU ARE SELLING
Username: Hnic_men
Post Number: 66
Username: Barass
Dont no why these guys are posting nothing to do with what i asked ?...... Bur hitch i tried that and still onlt get a few of the 110 channels ?
Username: Lklives
Post Number: 73
John...hook cables up to each LNB and then run each seperately DIRECTLY to receiver and THEN do satellite scan of that bird ,first 110, then 119..do NOT hook up disque switch..this will ensure U have BOTH good LNB alignments..if then both 110-119 are working well, THEN hook up disque switch and configure the remote antenna installation settings..
