1080i on Mitsubishi 46809 and SciAtl Explorer 8000 HD?
Username: Jakester
I recently had Comcast install a Scientific Atlanta Explorer 8000 HD DVR. Once they got the TV to recognize any signal, they bolted. However, I cannot get the TV to recognize any signal higher than 480i.
I have installed the RCA RGB component cables to the DTV inputs on the TV and then tried setting, through the Input Selection Menu of the TV and with the instructions provided with the set-top Explorer, the signal to 1080i. Nothing seems to work.
I have changed the settings between the RGB and the YpYb (or whatever it is).
Any idea as to what it is that I need to do to get the full benefit of the HD signals?
Thanks.
Username: D_singh
Post Number: 77
Maybe the DVR is programmed so as to not output 1080i or 720p signal in component output, but rather in an HDMI output or DVI output.
My Panny DVD player won't output 1080i or 720p unless HDMI is connected.
Just a thought...
