Dumb question
Username: Korso55
Post Number: 14
what can your do by unlocking codes to your dvd player?
Username: Samijubal
Post Number: 2004
Unlocking allows it to play discs from different regions.
Username: Korso55
Post Number: 15
im sorry could you explain that to me...i dont know what that means? what does that exactly do?
Username: Tom_nk
I'm guessing that it allows you to play DVDs formatted with the European PAL format in the US, which uses NTSC or vice versa. Is this correct?
Username: Samijubal
Post Number: 2008
No, it's not to change the system. Most DVDs have a region number on them, it allows playing discs from other regions. There may still be PAL/NTSC problems. This shows DVD regions.
http://hometheaterinfo.com/dvd3.htm
