Magnovox MRV640 dvd recorder
Username: Cdpymp
Houston, Tx Us
i need to know what dvdr works with this machine? the 4x that i have been buying do not work and the only one that works is the dvdrw that came with it. someone tell where to find the right dvdr or dvdrw.
Username: Samijubal
Post Number: 2002
You need +R discs. If you're trying to use DVD-R, they won't work.
