Signal Quality 119 & 110
Username: Bozza
When adjusting the dish and looking for signal quality for 119 and 110 which TP I should look under to get the best signal?
Letmeon
almost equal on all , mostly middle ones.
some will be zero between 2 good ones. trial and error.........
Username: H3lt3r_sk3lt3r
Post Number: 662
@Igz
A weak TP would be only specific to your area, some TP's are weak on the east coast some on the west.
Username: Bozza
thanks
