Digiwave7000 Time Settings
digiboy
I installed the latest file but the time in the egp is wrong. ie IT's 6pm and the time says 1pm???
Username: Cmoore
Windsor, Ontario Canada
Post Number: 23
You gotta go in the menu and set your clock.
Look for "Time Adjust"
If you mean the GMT setting i have done that. The local time is correct but the time above where it show what time the program starts and end is wrong? Is anyone else having this problem or is there something i'm doing wrong? I located in the eastern time zone so i set the GMT to -05:00. Anyone have any suggestions?
Username: Cmoore
Post Number: 27
In your Time Adjust Menu:
Set Local Time = 0:00
Summer Time = OFF
Year = 2005
Month = Nov
Date = 19
Hour = "Your Time" (Mine is Military)
12AM = 00:00
12PM = 12:00
1PM = 13:00
11PM = 23:00
Username: Thill1951akalk
Post Number: 773
GMT and military time are the same..all based upon Greenwich England which is ZULU time related..
digiboy
@ cmoore
Can you tell me which file you're using so i can hopefully get the problem resolved.
Username: Cmoore
Post Number: 28
@digiboy
The file is Called DIGIWAVE FIX.zip which includes:CasLink_v1.11.exe
Channel List.txt
Digiwave Nosing manual update key features.bin
FtLink3.01.exe
Read me 1st.rtf
Softcam.key
I used FtLink3.4 to load the bin only.
Loaded my own Channel List.
In Menu: System Settings: go to Key Editor: find Nagra 2, not Nagra 1, 0001 DishNetwork, and enter current Keys together in 1 string on Key00 line.
Go to Time Adjust and set as above.
F29874441C6577D817E3E11D894E5345
