That site is good to find sats ,thanks ... but ..on the dtv dish is setting the elevation the numbers on the mast to line up with 30,31 32 and so on .. it sais for dtv-5 select 27.4 i am asuming this is the elevation setting ?..is this right
Yes indeed ,but newbies need to start somewhere ,just have to find a legit FTA reciever sales company ,most seem to be scams . i am looking at the pansatt 2700a
DEMONIC
I HAVE A KOOLSAT 4000 PRO I WANT TO VIEW THE 101 LNB CHANNELS I HAVE THE CHANNEL LIST AND THE LNB IS UP ON THE DISH BUT CANT SEE CHANNELS DO I NEED TO CHANGE THE FREQUENCY ON THE LNB IN ORDER TO MAKE IT WORK.OF COURSE I HAVE 119 AND 110 BUT I ALSO WANT TO SEE 101 ALSO.CAN ANY BODY HELP
You can't veiw 101 you dipshit it's Directv and you can't get it without a subscribtion!
zzzzz
edmonton ab, can i get all channels on 110 for dish with 30" dish?
stc mike
Hi, I can get a number of dish channels including ppv, but cannot get headline news, espn, mtv, hbo, or cnn. I also get a lot of latin channels like HBOLT. Am I aimed at 121 instead of 119? Please confirm. BTW, located in St. Louis, MO.
Elclipes
Try this works good www.sadoun.com/Sat/Installation/Satellite-Heading-Calculator.htm
stc mike
Elclipes, Thanks for the link, but it doesn't have a choice for 121, echostar 9. Also, I have tried to find 119 assuming I am at 121 and can't get anything.
Elclipes
Anik E2 is 119 and Anik Er2 110 that is what I used
