Still Freezing
Robotic$
Downed the new 281 bin, I get all the channels but some freeze up, go black and then come back.
Is yhere something that can be done to fix that, or is that just the way it goes?
Don Stemeicky
I have same prob.can sombody help
Username: Jdq
Post Number: 78
Maybe you need a heatsink on your chip lotta receiver chips get hot with new files ,I ADDED ONE TO MY DGIWAVE AND NO MORE FREEZING
memememem
Your digiwave has sw fix for longer video packets, ultra does not.
d.ollzar
memememem, can something be done for the ultra?
D. Ollzar
memememem, or anyone
can something be done for the ultra because I have the same freeze problems?
