Need help
WHCKJ
Sorry, couldn't figure out where to put this...
i need some kind of system to send the signal from 1 TV to another. i have a DTV reciever in the media room and want to be able to send the signal to a cable ready TV in a workout room without adding another DTV box or running a cable. There used to be some kind of wireless transmitter and reciever for sale (rabbit maybe?) has anyone had any experience with this?
thanks, MJ
Username: Samijubal
Post Number: 1600
I haven't used one for a few years. The quality is poor, and they are picky about where they are set up. Much better to run cables if possible.
I have a Magnavox Computer Color big screen which was working fine until it was moved. It will stay on for about 30 sceonds and then shut off showing battery failure. This tv was manufactured in 1987 and I understand it does not have a picture tube. Could it be a wire that has come loose? Could someone please help me.
