Universal LNB vs Standard LNB
Jim K
Hi,
is there anyone knows what is the diference between
Universal LNB vs Standard LNB?
can I get dishnet with Universal LNB?
or can I get fta channels from TA5 with Standard LNB?
martin23
this is my question too...
someone tell us about
Username: Decko
Toronto, Ontario Canada
yes
but your lnb need to be for fta
ask me any thing
Jim K
hey decko
what do you mean by"lnb need to be for fta"?
simply I am using a standard LNB for dishnet and my question is when all the channels went down can I just turn the dish to TA5 or I need to replace the LNB with a universal one to get those fta channels?
by the way, I am in Toronto too
i am from st.lucia in the carribean and i need to know if what reciever would be the best foe free channels
free channels
youll need atleast a 33in dish with a KU lbn to get fta channels
sally parker
what kind of KU lnb?
Universal or Standadrd?
LK
Universal linear LNB ([link removed] or www.ftasource.com LNB-$29.99) and a 30-36 inch dish is needed for T5 97W bird..the bigger the dish,the better to receive those weaker signals and lower frequencies with the Universal LNB..
LK
What are you using for an LNB/LNBF? A standard DBS LNBF (DN/BEV) in North America covers frequencies from around 12200-12700 MHz, uses circular polarization, and has an I.F. of 11250. If that is what your are trying to use to get IA-5 Ku, then you would be better off with either a standard North American FSS band (11700-12200 MHz), linearly polarized LNBF or a universal (10700-11700 MHz, 22kHz off; 11700-12700 MHz, 22kHz on), LNBF that is also linearly polarized, since IA-5Ku is linearly polarized and operates in the NA-FSS band. Your receiver would be set up according to what LNBF you are using as to I.F. Frequency and 22kHz settings.
Standard LNB for use above 12200 frequency.
Universal(which is linear) LNB good for low frequecies < 12200
Username: Maple_leaf
Post Number: 649
Like you would LK . Stupid nutcase.
ThiIl 1951
MAPLE LEAF HAS GONE BERSERK
Post Number: 655
Better go see the TOP mod so you don't get in trouble.
LK
-(MABLE LEAF)-Got my "nuts" in his mouth...
He's going for my dick now...
O no he just swallowed my dick...
O,O,O,O, I just came my lump in his
mouth...
O my, the cream is running out of
his mouth...
O Mable loves it he is smiling and
laughing...
O me, O me, O me, he won't go away.
sally parker
Thanks LK
I got all I needed,right now I am using 33" dish and a standard LNB to get 119',I will get an Universal LNB for the time dishnet is down and swtich to T5 97
