New member Username: BlindeAsdf, CA United States Post Number: 1 Registered: Jun-05 | myl mitsubishi 50" has suddenly gone wacky. if you know what is wrong with the t.v. and can recommend a tv repair person in the s.f. bay area who makes house calls, or whether this is a REPLACE instead of a REPAIR, please email blinde@5happy.com |
Anonymous | Looks like a three dimentional grid from the service menu. Nice reflection of your windows and curtains on that glaring Mitsu screen. I see you sitting there too! You might consider placing the set on the window side of the room facing in. You don't have a small button pushing child do you? That's a bizarr test pattern! Have you tried unplugging the set for a few minutes? |
Silver Member Username: Thx_3417Bournemouth, Dorset United Kingdom Post Number: 300 Registered: May-05 | Plus I can see major convergence errors too, it maybe a simple fact, look at the manual, for troubleshooting. If all fails there maybe a dry joint on the PCB or a IC that's malfunctioned, if that is the case the cost will be quite small. |
grfunk Unregistered guest | Bad capacitor or capacitors in the deflection circuit. Easy to fix if you're a tech. Shouldn't cost much. |
New member Username: BlindeAsdf, CA United States Post Number: 2 Registered: Jun-05 | grfunk - thank you for the specific response to my question(s)! i was thinking a bad cap or solder joint. i'm not a tech (although i know enough to get myself in trouble), and i don't have the servce manual. there is a local company sending out a guy later today... $80 for the service call, we'll see. thanks again, bline |
grfunk Unregistered guest | $80.... Yeah, those things are hard to take in yourself unless you have a truck. I hope they don't hit you with board replacement but they might do that since a lot of shops won't get down to component level repair. I wonder if they would do that type of service in your house anyway. I'm able to take care of my own electronics so I don't call out. Let me know how things come out. |
ogbuehi Unregistered guest | typical DLP picture-minus the rainbows. if you get close can you hear fan or color wheel noise? check out the lcd projection- |
grfunk Unregistered guest | ogbuehi, You sell LCD projection tv's or what? |
Anonymous | That's not ogbuehi's post! It's a hi-jacker! |
grfunk Unregistered guest | I kinda figured. Someone with nothing better to do or say. |
Dlp4Rme! Unregistered guest | typical DLP picture-minus the rainbows. if you get close can you hear fan or color wheel noise? check out the lcd projection- |
MITSIBUSHY STIR FRY Unregistered guest | I AGREE-typical DLP picture-minus the rainbows. if you get close can you hear fan or color wheel noise? check out the lcd projection- |
KLAUSS/MITSIBUSHY Unregistered guest | I'm a bullsh!t hi-jacker! Better not listen to me too close. I'm so confused! I stared at my Sony screen door too long. I think 60XS means 60 Xtra Stuck pixels! I'll bullsh!t you every chance I get! |
Anonymous | You're that disturbed unregistered hi-jacker! Hey DLP4RME!/LCD4ME!/KLAUSS/MISH/MITSIBUSHY, Sony sucks! Don't let that screen door hit you in the face! Retarded idiot! |
Anonymous-DLP4me!-Klaus Unregistered guest | You're that disturbed registered hi-jacker! Hey DLP4me!,Klaus-DLP SUCKS! can you sing-"SOMEWHERE OVER THE RAINBOW",as the "claymation",and fan and color whell noise are in the background. |
Anonymous-DLP4me!-Klaus Unregistered guest | I'm so confused! I'm that disturbed hi-jacker with the Xtra Stuck 60 pixels and the screen door up my a$$! My Sony exploded and I got me a DLP. It's wonderful! Sony CS won't send a proctologist so I guess I'll be sifting sh!t for some time. |
Anonymous | Boards gone to hell! Pease...out! |
