Moisture between Theatershield and screen, how to get rid of it??
Username: Jhngh41
I have a 2 yr old who likes to leave hand marks on the theatershield along with whatever else is on her hands. Well, I wiped it clean a couple days ago with a slightly damp towel and some how the moisture seeped in and now there are moisture spots near the bottom of the screen between the shield and the screen. Should I take the screen off and dry it manually or will it dry itself over a couple days.
