Adding a Dish 510 receiver to pansat's "if output"
FTA-Lover
LK/bosox..instead of using a spliter, if i connect dishnet 510 to my pansat 'if output' would Dishnetwork find that out? Once I do this, I know It is only possible to watch the same SAT on both receivers(but different channels) and this is ok since I will only be watching one receiver at a time. Am I going to send some kinda signal to Dishnet because the input to dishnet510 receiver is coming from 'if output' of my pansat? Will they know that I am using an FTA? Thanks!
FTA-Lover
Is anyone out there whos got any suggestions or comments about this?
Username: Knee_grows_back
Post Number: 350
Bosox is gone...if you want my help you are going to have to ask me nicely and butter me up for a superb answer...
FTA-Lover
Ok mr. kneegrow seems like now ur the man so instead of using a spliter, if i connect dishnet 510 to my pansat 'if output' would Dishnetwork find that out? and also please answer the other questions I asked. I thank you so much. UR the greatest.
No, he just wants to bash you.
FTA-user
I guess the answer is 'they will find out'
GrowerX
Bosox went to A1 Plasma & Satellite
Qstn-4-LK
LK..if you are back, will you answer this?
LK
No way will Dishnet know of your FTA..phone line is only way Dishnet knows anything..
LK
IGNORE KNEEGROW......ITS THE ONLY WAY
FTA-Lover
Thanks LK ! Most people here appreciate all your help and hoping you won't be annoyed by a lil pri*ck like knee-grow.
I have a legal dishnet 510 receiver that came with a nagra2 card,is it possible to use that card in another 510 receiver?.
Just George
No cause its "married " to that receiver.Dishnet can only unmarry it.
