Bronze Member Username: Rbhoop
Post Number: 49 Registered: Jun-06
Posted on Hi all Just wondering can i get both dn and bev with an 18 in dish with 2 lnbs and which sat would i point to Thanks for any help |
Silver Member Username: Sump
Post Number: 369 Registered: Aug-09
Posted on what is is pointed to now ? what box ... |
Platinum Member Username: Plymouth
Post Number: 11031 Registered: Jan-08
Posted on ron No you can't! Buy another 18" and point one on 110W/119W and the other on Bev 91W.
Post Number: 370 Registered: Aug-09
Posted on Ron you CAN get either/OR ... with that setup you could buy LNB bracket though if you are HD then you'd want 82 also .. |
Silver Member Username: Rtf
Post Number: 107 Registered: Aug-07
Posted on ron if you add a dish or LNB you will also need a switch(there are many different types available), read up on them. your setup page for the different sats will start to make a lot more sense to you after you do. |
