Bronze Member Username: MatiPost Number: 33 Registered: Apr-08 | Cananyone assist me in trying to format aHarddrive in dos format?FAT32 to NTFS i tried using a windows XP3 Thanks Eugene |
Gold Member Username: PlymouthCanada Post Number: 6543 Registered: Jan-08 | Yugene Use this freeware for it, i had do some surch and this is one of best http://www.compuapps.com/download/Swissknife/swissknife.htm ![]() |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2293 Registered: Dec-06 | are you trying to load Windows Xp sp3 onto the hard drive or just convert the Fat32 to NTFS? |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2294 Registered: Dec-06 | How to convert a FAT volume or a FAT32 volume to NTFS Note Although the chance of corruption or data loss during the conversion is minimal, we recommend that you perform a backup of the data on the volume that you want to convert before you start the conversion. To convert an existing FAT or FAT32 volume to NTFS, follow these steps: Click Start, point to All Programs, point to Accessories, and then click Command Prompt. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfs Note If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT. Enter the current volume label for drive drive letter When the conversion to NTFS is complete, you receive the following message at the command prompt: Conversion complete Quit the command prompt. Here is the link incase things don't go well you can read the trouble shooting info http://support.microsoft.com/kb/307881 |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2295 Registered: Dec-06 | if you have anymore questions regarding installing window xp or Vista just pm me and i can assit you in any way. I hope this helps |
Gold Member Username: PlymouthCanada Post Number: 6548 Registered: Jan-08 | Doreen i think yugene want convert NTFS in Fat32 for his receiver. ![]() |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2297 Registered: Dec-06 | HUH? |
Silver Member Username: AjdarwinPost Number: 279 Registered: May-06 | Some of the DVRs use Fat32 as the file system for recording movies. That being the case it may be necessary to format the hard drive before installing it. I have a DVR which uses Fat32, but it will format the hard drive on it's own. You can boot up your computer with a Win98 or WinMe boot disk and format the hard drive that way. I tried this when I increased the hard drive size from 80 gig to 300 gig. It worked fine, but my hardware (DVR) is hacked to accomodate the change in hard drive size. |
Gold Member Username: The_codersPost Number: 1628 Registered: Jan-08 | Or do it the ez way - "Partition Magic" , windows can only format fat32 up to 32gig. Here's a link for free partition magic: |
Gold Member Username: PlymouthCanada Post Number: 6573 Registered: Jan-08 | The Coders sometimes Partition Magic not work that why i give SwissKnife. http://www.compuapps.com/download/Swissknife/swissknife.htm ![]() |
