Gold Member Username: Cartier1Post Number: 2258 Registered: Feb-07 | we had trouble getting the signal using globcast dish to get 97w. does the lnb goes bad in this dish ????![]() |
Gold Member Username: JustforhahasPost Number: 1589 Registered: Jul-08 | Its just like any other larger dish...LNB's rarely go bad on any dish!...aim it, run the cable, and input CORRECT settings... |
Gold Member Username: Cartier1Post Number: 2259 Registered: Feb-07 | we aim we run the cable and we input the CORRECT setting and no signal . we will try to change the lnb. and see what will happen. |
Gold Member Username: PlymouthCanada Post Number: 6494 Registered: Jan-08 | Cartier Be sure you have a linear LNB. Here is the good setting: LNB Type: standard LNB Freq: 10750 Tp Freq: 12153 try this strong Tp 158 TV channels now on galaxy 19(25) 115 Radio channels ![]() |
Gold Member Username: PlymouthCanada Post Number: 6495 Registered: Jan-08 | Catier Don't forget to adjusted the skew on your LNB. Use it dishpointer.com ![]() |
Gold Member Username: Cartier1Post Number: 2260 Registered: Feb-07 | PLYMOUTH the dish is globcast original . used for couple mounths. i think the lnb is damaged cuz i could get 1 channel which is local channel with very low symbol rate 3.900 somthing like this . |
New member Username: RobotelulPost Number: 5 Registered: Jul-06 | Cartier if your lnb is that one from the photo this is an Invacom and depending of your receiver your settings should be something like Lnb type Universal High 10600 (not 10750) low 9750 |
Gold Member Username: Cartier1Post Number: 2261 Registered: Feb-07 | rvv thanx . the ;nb is original globcast. it's frequency is 10750 not 10600 |
Gold Member Username: PlymouthCanada Post Number: 6503 Registered: Jan-08 | RVV We don't use Universal LNB here in North America, Tp Freq 10600 is not use here, only 10750. Universel LNB is use in Europe not here. Only if you scan 2 Freq. as for 118-119 on same satellite there you can use Universal(11250-10750). If you use 10600 you will not get all channels. Cartier Dismount your LNB and put it on heat source for the night and retry it tomorrow, mark the skew position. ![]() |
Silver Member Username: SccrskillsPost Number: 133 Registered: Dec-06 | actually i think mine is also set on universal for globecast and i get all my channels. |
Gold Member Username: PlymouthCanada Post Number: 6505 Registered: Jan-08 | Sccrskills The good setting is standard 10750 but it work too if you use Universal if your LNB high is 10750. ![]() |
Gold Member Username: Cartier1Post Number: 2262 Registered: Feb-07 | IM NOT SURE IF U GET HOW THE LNB IS MADE IN GLOBCAST DISH. THERE IS NOTHING TO SKEW IT'S MADE ALREADY ADJUSTED. IN FRONT LNB THERE IS BAR WITH ALL ANGLE AND NUMBERS. IT COME ALREADY SET FROM THE FACTORY. I STILL BEL;EIBE THERE IS DEFECT OF LNB . \SCCRSKILLS THERE ARE 2 SETS FOR UNIVERSALS. UNIVESRAL1 LNB FREQUENCY IS 10600 U STILL CAN GET MANY CHANNEL BUT YOU CAN NOT GET SOME. UNIVERSAL2 IS SET FOR 10750 . DEPOND WHAT CHANNELU WANT . MOSTLY IN EUROP OR MIDDLE EAST THEY USE THE ONE THAT HAS FREQUENCY 10600 |
Gold Member Username: Cartier1Post Number: 2264 Registered: Feb-07 | the lnb has same head like invacom. these are the picture. if we wanna replace the lnb . there is no mannual on what u position you have to put . ![]() |
Gold Member Username: Cartier1Post Number: 2265 Registered: Feb-07 | here the rest![]() |
Gold Member Username: PlymouthCanada Post Number: 6508 Registered: Jan-08 | Cartier the skew is in back of dish as for Bev dual LNBs Read this info on Globecast dish: http://www.sadoun.com/Sat/Products/GlobeCast/GlobeCast-Elliptical-Dish-LNBF.htm ![]() |
Gold Member Username: PlymouthCanada Post Number: 6509 Registered: Jan-08 | Here is the installation guide http://www.sadoun.com/Sat/Products/GlobeCast/75e_new_manual.pdf ![]() |
Gold Member Username: Cartier1Post Number: 2266 Registered: Feb-07 | thanx plymouth. yeah i did the skew . in my case it's 115 . . we ordered a replacement of lnb . cuz there is no other way . everything is good but that dish gave us trouble. we did install an otherone in an other house and everything is good . |
Gold Member Username: PlymouthCanada Post Number: 6520 Registered: Jan-08 | Cartier You are Welcome ![]() |
