Bronze Member Username: Kat2008
Post Number: 26 Registered: Dec-07
Posted on I was trying to load the latest bin and when I clicked the PCB to STB button it say error occured.Please help. |
Bronze Member Username: Mrgreg
Ont.
Post Number: 51 Registered: Dec-07
Posted on kat, Make sure you have the right com port.Usually #1 unless you are using USB port. |
Post Number: 27 Registered: Dec-07
Posted on Thank Greg.But I am using the null cabel modem. |
Ont.
Post Number: 52 Registered: Dec-07
Posted on kat If you are using cable from pc to rec. it should be on com 1.Check your port by going into your config. setting in left top corner of loader. |
Post Number: 28 Registered: Dec-07
Posted on Greg, It's in com 1 |
Ont.
Post Number: 53 Registered: Dec-07
Posted on kat, Download a new bin file and try it again.Make sure you are using loader 2. |
Post Number: 29 Registered: Dec-07
Posted on Greg, I've download the new bin file and also the Loader2 from FTA HQ and still I get the same error. |
Ont.
Post Number: 55 Registered: Dec-07
Posted on kat Have you ever loaded files before and are you sure you have the right cable. |
Post Number: 30 Registered: Dec-07
Posted on Yes! Greg, I have been using the same null modem cable for more than a year now. |
Ont.
Post Number: 57 Registered: Dec-07
Posted on kat Are you backing right out of the loader each time you retry. |
Post Number: 31 Registered: Dec-07
Posted on YES GREG. It's just display the channel # on the rec and on the PC it showing resending the file and latter shows error occured. |
Ont.
Post Number: 58 Registered: Dec-07
Posted on kay Are you turning the power switch on at the back of the rec.at the same time as your hitting pc to stb button. |
Post Number: 32 Registered: Dec-07
Posted on Yes! Greg I did everything. But still I am unable to upload the bin. |
Ont.
Post Number: 65 Registered: Dec-07
Posted on kat, Try loading factory file V0279 then most recent bin file. |
Gold Member Username: Plymouth
Post Number: 5487 Registered: Jan-08
Posted on Kat Use the new loader from viewsatusa.com Load the new factory file and the new satellite info then load the latest file from ftahq.com Dont forget to unzip it
Post Number: 33 Registered: Dec-07
Posted on Thanks Greg n Plymouth. I will give it try tomorrow. If it doesn't work I will let you know. Have a Good night. |
