SV4000 fix still has freezing?
Username: Upreferee
Post Number: 71
I've heard the SV4000 263 file still has freezing issues.
Username: Justforhahas
Post Number: 1124
Try it and find out...then you will know ...all receivers are not the same..
Username: Juancho
CANADA Xx
Post Number: 201
here is why.
This was a tricky one!!
c/p Cyphris 11/11/08
This new timer also caused subs to be effected for short time as they made a change after initially implementing the ECM which involved an EPROM change. Others have released with still some freezing and those who were initially not affected did have some signs of freezing. VS coders have been testing and have this one licked. New files will be out in no time now.
posted 1 hr ago
Username: Plymouth
Post Number: 5478
Thanks for the info Juan
