Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3653 Registered: Oct-06 | Hello everyone I got a great question for Satellite hobbyists Can yo put a linear LNB on a 24" dish? Can yo get FTA on a 24" dish? The answer is yes mainly on Galaxy 18 at 123.0°W But it depends on where yo live East cost is the only answer I never tried it But I advised few hobbyests on the east cost they came back thrilled to tell me it does work great But yo have to look at the map below: ![]() Here is how to: - first look at map to determine yor location - Basic linear LNB - Dish 500 or old DTV dish 20" to 24" - Yo'll need to determine 3 items: * Azmith * Elevation * Tilt skew for LNB Use: Put yor zip code and selecting Galaxy-18 123W Please note linear LNB requires rotation inside its universal bracket or entire dish to be moved if yo are using rectangular linear LNB Make sure yo use a KuLo LNB (KuLo=11.7G) This is a great LNB can work as Linear or Circular even on 118.7 Zinewell ZKF-G52N or digiwave 12.2-12.7GHz It's a dual LNB for about $20 Can work on an old DTV or dish 500 I base my calculation on a 49dbW Dish size 55" to 65" from above table Average is 60" 60/2.5=24 BELIEVE ME GUYS IT WORKS Yo can also get C-band on a 1.2Meter dish https://www.ecoustics.com/electronics/forum/home-video/498353.html |
Silver Member Username: DimwittPost Number: 972 Registered: Aug-06 | C-band With a Ku-band Dish www.dbstalk.com/attachment.php?attachmentid=10965&d=1194840465 |
Gold Member Username: PlymouthCanada Post Number: 4962 Registered: Jan-08 | Good post Tooter![]() king i will try this satellite later and confirm you if i can get it ![]() |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3654 Registered: Oct-06 | It is a good presentation He's right about one thing Newer satellites got stronger signal But this individual is unaware that signal can be calculated and size of dish can be determined by signal level value straight from foot prints Also he's totally unaware that it depends on which satellite and where he lives My first post is to show everyone that a 24" dish can be used on a linear LNB And there is no need for trial and error Size of dish can be easily calculated from foot prints Trust me It works just like I explained above |
Gold Member Username: PlymouthCanada Post Number: 4966 Registered: Jan-08 | King I repaired my problem with my motor, a simply bad contact on a connector. I see this satellite this morning on Lyngsat, but not scan it. I scan Galaxy 18 tonight and i get 20 channels, but i have a big tree btw the dish and 123W position. This satellite provide a strong signal if i consider my location and the neighbor tree directly in signal. I am sure than everybody from USA and Canada can get this satellite from a dish size btw 18" and 36". The interesting thing is: this is probably the best satellite Ku Free to Air Local Channels for now. Thanks for the info King ![]() |
Gold Member Username: PlymouthCanada Post Number: 4984 Registered: Jan-08 | King """It is a good presentation He's right about one thing Newer satellites got stronger signal But this individual is unaware that signal can be calculated and size of dish can be determined by signal level value straight from foot prints Also he's totally unaware that it depends on which satellite and where he lives""" ---------------------- All test are performed from Toronto. Note i get many channels not available if i look on chart from Lyngsat from my position with a small 90cm dish. ![]() |
