chris sada is here.. here you go..posted way back ... obama fu*ck off.
sada Gold Member Username: Saqeeb9000
Mughe dard rehta hai, ..., Mujhe bhook ...
Post Number: 2849 Registered: Oct-07 Posted on Saturday, March 15, 2008 - 04:13 pm:
-------------------------------------------------------------------------------- 1. Open Internet Explorer 7 2. Click on Tools 3. Click on Internet Options On Internet Options Screen Click on Advanced tab Scroll down to Http 1.1 settings Uncheck the following Use HTTP 1.1 Use HTTP 1.1 through proxy connections Press OK Created by: HumanNetwork f2atv.com On the internet explorer address bar Type your STB's IP Press OK Username: admin Password: 0000 (default) Now you should see Webloader interface Click Browse... Created by: HumanNetwork f2atv.com Browse to the file you download. Make sure you unzip it. And it can only load software, NOT boot Click Open Click on Upload File Now you should see this screen. It is telling you upload to your stb is successfully. Keep an eye on your stb it will reboot. When it come back Press Menu->User Settings- >S/W Version You should see new version
yep plymouth... here is some further help chris.. do this for latest file... sada Gold Member Username: Saqeeb9000
Post Number: 3462 Registered: Oct-07 Posted on Thursday, July 03, 2008 - 07:42 pm:
-------------------------------------------------------------------------------- no james...... what u need to do is go to menu , internet, then network information, find ur ip adress...... now write down ip adress at some paper.. now go to internet browser, in adress bar type ur ip adres. just like you type [link removed] [link removed] some hints .. when u are putting ip adress in adress bar, change the channel or some times tune in to 100 or 102 channels also help.. when u will type ur ip adress u wil get in to webloader, over there locate ur 1.47 bin that u saved and then clik on upload wait 1 min........ and ur rec will turn off and on again.. to check if u have latest bin, check under menu system setting, it should says 1.47.. after thaat if u still not up, go to menu usersetting and turn off emulator and autorolls on... this should work.....
Post Number: 3475 Registered: Oct-07 Posted on Saturday, July 05, 2008 - 03:52 pm:
-------------------------------------------------------------------------------- some suggestion for people whose webloader is not working.......
if u can not use ur microsoft internet explorer try mozilla fire fox..always works better for webloader... also when u are putting ip adress on ur adress bar when u hit enter, change the channelalways works.. 3rd method u can also download the channel editor program (1.10) from [link removed] and then use the program there to grab the bin, works faster... also if u are doing it withur laptop computer try to do it with (network cable).. better connection... last thing if u still can't do it do it old fashioned way..with serial cable check am's post above...
yes i forgot now u can upgrade simply through the remote ,thanks cartier menu,internet,swversion upgrade and enjoy.. webloader and channel editor are good if you wanna keep the channels u saved , u don't have to download it everytime..
How can an alleged experienced Nfusion owner (sada) FORGET, a simple upgrade method by simply clicking on a button on the remote..
Did you FORGET to plug in your receiver too?
sada is the last person on the planet I would believe or accept any advice from....use most any other legit forums (not here) with many mods/admins who truely know FTA and using the Nfusion..those people don't "FORGET" basic simple things..
Post Number: 236 Registered: Aug-06 Posted on Saturday, October 11, 2008 - 07:03 pm:
-------------------------------------------------------------------------------- I fully trust Plymuoth and Sada. They are honest & have often helped nubi like me many times. So trust them.
neil, you are saying that Plymouth and Sada has help you? here or the Audio Section? Are you the real Nalin or just another passing by bullshitter?
Buddy, think what you want. In my openion, Nalin, Plymouth and Sada know more about FTA than you and me put together. Why dont you quit this bull? Live and let live and you will live happliy ever after. You must be an unhappy person.
By the way, Kingsville, I have a masters in electrical engineering but I dont feel asamed to ask for advise even for little things. You learn something every day by a good communication. Not every one is born perfect like you.
neil...I've been in this hobby for 10 years..and around here for many years...and I can tell you 100% that nalin, plymouth and sada have NO clue about this hobby, but pretend to, and can only provide the most basic of info that anybody would know after 1 month here..in fact, plymouth and nalin are the same person working here to monitor you and the FTA world...don't be fooled by them...You've been warned..and sada is just not very smart and often asks others here how to use his own nfusion...or he may be a part of that Mole team with plymouth and nalin (still unsure of sada's role here now)..is he just dumb or dumb like a fox..
Neil Hahaha is a old member ban from here because he have a cervical problem, he see Nalin everywhere. He is too idiot for see that many times we post in the same minute.
He is a Mod on another sites and is here for discredited Ecoustics nothing less.
Ecoustics is the best sites for help, if you do a search on Google and yahoo, you always found Ecoustics in the result.
neil I didn't mean to get too your feeling Sir, but you did say that Plymouth and Sada has help you. I didn't see the posts where these two have help you.
neil Silver Member Username: Frobi
Post Number: 237 Registered: Aug-06 Posted on Sunday, October 12, 2008 - 12:58 pm:
-------------------------------------------------------------------------------- Buddy, think what you want. In my openion, Nalin, Plymouth and Sada know more about FTA than you and me put together. Why dont you quit this bull? Live and let live and you will live happliy ever after. You must be an unhappy person.
What Bull are you, Sir talking about? It looks like you have the Bull I just ask you a simple question which you didn't answer.
Don't worry who I am or what I am, just answer my question.
How can an alleged experienced Nfusion owner (sada) FORGET, a simple upgrade method by simply clicking on a button on the remote.. poste by haha.. if you don't know then don't talk, last bin they started back the old fashioned way,using remote,but when the server is busy you have to do it with webloader, and as i mentioned earlier webloader is good way to save channels list too but you don't know about technology and u don't have nfusion, so enjoy scrambbling channel on your sonicview during ecm..
Post Number: 68 Registered: Jul-08 Posted on Sunday, October 12, 2008 - 02:35 pm:
-------------------------------------------------------------------------------- neil I didn't mean to get too your feeling Sir, but you did say that Plymouth and Sada has help you. I didn't see the posts where these two have help you
well here you go
Post Number: 3750 Registered: Oct-07 Posted on Tuesday, August 26, 2008 - 02:55 pm:
-------------------------------------------------------------------------------- neil Silver Member Username: Frobi Post Number: 222 Registered: Aug-06 Posted on Tuesday, August 26, 2008 - 02:39 pm: Edit Post Can some one please help with nfusion? What is the latest bin and what loader should be used? Do you load it the same way as VS extreme or CW600P? Thanks Relevant Product Info
Post Number: 3751 Registered: Oct-07 Posted on Tuesday, August 26, 2008 - 02:57 pm:
-------------------------------------------------------------------------------- neil the latest bin for nfusion is 1.48. yes you can load the bin like viewsat extreme or u can ue innovative method webloader to download the bin.. all the files are available at [link removed] [link removed] [link removed]
Post Number: 3752 Registered: Oct-07 Posted on Tuesday, August 26, 2008 - 02:59 pm:
-------------------------------------------------------------------------------- [link removed] here is the link for latest file
Post Number: 224 Registered: Aug-06 Posted on Thursday, August 28, 2008 - 11:16 am:
-------------------------------------------------------------------------------- Thanks again sada.
Posted on Sunday, October 12, 2008 - 01:33 pm: Edit Post Nalin and Plymouth, thanks for helping me out to hook up a third receiver. Nalin, I took your advise as you said to use two splitters on each LNBs and use another switch. Worked perfectly. Plymouth, about missing channels. I followed your guidence by loading doing a factory default, load an older bin, blind scan, load new bin and got all missing channels.
Post Number: 65 Registered: Jul-08 Posted on Sunday, October 12, 2008 - 09:27 am:
-------------------------------------------------------------------------------- sada Gold Member Username: Saqeeb9000
Post Number: 3988 Registered: Oct-07 Posted on Saturday, October 11, 2008 - 09:01 pm:
-------------------------------------------------------------------------------- thanks neil and plymouth you and nydas are best helper at ecoustics..
sada, I am little confuss didn't you once report Nydas to the Admin?
king , sada never reported nydas to the admin. pay attention to the user name and post number . there little faggggggg here that change his name to others look a like user names so they ruin their reputation. . no one here is caliming to be god but what is wrong if someone forget or misunderstand an fta information . no big deal . so king go have a fresh juice and watch tv .
Cartier ...you have never fooled me but maybe others...I KNOW FOR A FACT THAT YOU ARE A ECOUSTICS MOD/ADMIN HERE...NO MATTER WHAT ROLE AND "DUMB AS A FOX" ROUTINE YOU PLAY!...I've had you in my scope and zeroed in for years!...I OWN YA, PAL!...SAY HI TO CHARLIE FOR ME..
justforhaha's Silver Member Username: Justforhahas you are an idiot . im using the same user name since day 1. you are LK .remember when i used to drive your fuccking life miserable ,you and others here, i dont do it anymore .used to be fun for me but not anymore.
i said hi to charlie from you and he said that you are fuckking morron , do u want me to say something eles to him.?
