Hi, I have a viewsat extreme and a cw600s Premium and I recently installed satellite 91 for bev (Nimiq1 1). I can view bev on the cw but am unable to view it on the vs. It always says autoroll processing.
I have tried everything I can think of. I checked the settings of my satellite, rescanned the satellite about 5 times, I changed the switch, I even put on the factory bin reset to factory settings and loaded the latest bin (07/30/08 from [link removed]). But it is still not working.
Can you please advise me on what to do. Your help will be greatly appreciated!
try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote "NEW" do same thing with all provider on Bev provider 09 07 00 09 06 00 09 05 00 09 01 00 08 01 00 no need to delete keys load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll, freeze and search signal
"Dont load factory bin"
Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV
Have you had the viewsat working before? When u load bin do you wait for the reciever to say insert and then end before shutting it off? It your main menu in installation where it says Nimiq 1 does it say nimiq 1 in the top corner also? Viewsat extreme has got to be the easiest box to get going.
I tried what you said above Plymoth. At first I was getting only 08 01 00 and 09 01 00 provider id's under bell. After deleting those 09 05 00 also showed up but it still isn't working.
I have DN setup for 2 years now and thats working perfectly fine. Could you please advise me on what to do next. Thanks
