Which bin working for converted FLU?
Username: Babulal
Post Number: 53
Anyone know which bin is currently working for a converted FLU? (using b75 not PUFF).
Thanks.
Username: Babulal
Post Number: 54
Just tried an old bin: 263_p122654_b-75 and it works!
Username: Nydas
Post Number: 10854
263 BIN is still working for converted 2500/FLU.
If having problems try switching off and on again using the switch at back
Username: Elvirm
Post Number: 34
Where I can find 263 BIN?
Username: Nydas
Post Number: 10860
Either b75 or PUFF
http://public.box.net/2500_full_kit
and select appropriate section
Username: Sachyadeewana
Post Number: 22
I loaded the 263 fwank Puff bin but BEV is down...any comments anyone?
Post Number: 23
Username: Elvirm
Post Number: 35
I put 263 bin b75, but nothing, all down.
Username: Nydas
Post Number: 10862
It is working fine with conversion BIN b75_263. You may have to do a full setup.
Download the full kit, unzip in a separate directory and read the instructions.
