Silver Member Username: Lol
Post Number: 519 Registered: Sep-06
Posted on Current Plat file dated 04/03/2008 is here ---> http://www.evilshare.com/12ddce4a-532d-102b-8d56-00a0c993e9d6 Current Xtreme file dated 04/03/2008 is here ---> http://www.evilshare.com/5721b5a8-532d-102b-8d56-00a0c993e9d6 Current Ultra file dated 04/03/2008 is here ---> http://www.evilshare.com/397519e6-532d-102b-8d56-00a0c993e9d6 Current VS9000 file dated 04/03/2008 is here ---> http://www.evilshare.com/dacc815e-532c-102b-8d56-00a0c993e9d6 pvr file dated 03/28/2008 is here ---> http://www.evilshare.com/7820e87a-4dcc-102b-8d56-00a0c993e9d6 |
Platinum Member Username: Donnie1973
Post Number: 2837 Registered: May-06
Posted on i wouldnt try those files!! |
Silver Member Username: The_coders
Post Number: 829 Registered: Jan-08
Posted on Thanks dood ! |
Platinum Member Username: Plymouth
Quebec city,
Quebec
Post Number: 1484 Registered: Jan-08
Posted on Thanks very much Paul youre the best |
Bronze Member Username: Im5150
Post Number: 70 Registered: Feb-07
Posted on anyone try them yet |
Silver Member Username: Aanaa
Post Number: 231 Registered: Mar-05
Posted on so 4 pansat 2700? |
Post Number: 71 Registered: Feb-07
Posted on aaaaa please read before you post |
Post Number: 830 Registered: Jan-08
Posted on tested and all back up ! thx agin Paul |
Gold Member Username: Way2smart
Www.Desifta.com
Post Number: 1452 Registered: Oct-06
Posted on All vs at [link removed] |
Bronze Member Username: Cdeepak
Post Number: 21 Registered: Jan-07
Posted on working!! I wonder how come VS fixes are coming in few hours for the past one month. |
New member Username: Boomer32
Post Number: 2 Registered: Jan-08
Posted on Thanks from me to Paul. Works great |
Silver Member Username: Metallica
Post Number: 553 Registered: Jan-08
Posted on Thank You Paul. |
Post Number: 832 Registered: Jan-08
Posted on why register at your stoopid racist site when they can get them all from the links above , not too smart are we smart 1 |
Silver Member Username: Leafs
Post Number: 553 Registered: Oct-07
Posted on viewsat files are posted at www.ftasolutions.co.nr |
Platinum Member Username: Way2smart
Www.Desifta.com
Post Number: 1456 Registered: Oct-06
Posted on just had 142 hits in 2mins ( i guess i am smart) |
Bronze Member Username: Potshot
Post Number: 16 Registered: Nov-06
Posted on VS Ultra file doesn't work. It reads but it won't install. |
Quebec city,
Quebec
Post Number: 1485 Registered: Jan-08
Posted on Ultra work fine for me |
Bronze Member Username: Xdamianx
Post Number: 12 Registered: Dec-07
Posted on VS Ultra doesn't work. Install get's hung up at 100%. I've tried it twice and both times it's stuck at 100% Sending ZEOF |
Www.Desifta.com
Post Number: 1459 Registered: Oct-06
Posted on use a usb stick.... or get the latest loader 2.1 from [link removed] |
Post Number: 837 Registered: Jan-08
Posted on mebbe corupt file , d/l it agin |
Silver Member Username: Abj
Post Number: 551 Registered: Feb-06
Posted on got mine from dss rookie for plat. working fine here. |
Post Number: 17 Registered: Nov-06
Posted on Grabbed another version of the file from FTAview.com. Works good. Happy Hackin! |
Post Number: 13 Registered: Dec-07
Posted on i used the USB stick instead of cable and it worked. thanks |
Silver Member Username: Halo
Toronto,
Ontario
Post Number: 456 Registered: Oct-07
Posted on New files released at www.dishkeys.co.nr! |
Bronze Member Username: Chadap
Post Number: 23 Registered: Nov-07
Posted on what about VSPVR7000? |
Silver Member Username: Dizasta
Post Number: 135 Registered: Nov-06
Posted on Where's the pro file |
Post Number: 521 Registered: Sep-06
Posted on Pro or PVR hasn't been release yet |
Post Number: 554 Registered: Jan-08
Posted on Extreme working great. Thanks again Paul. |
New member Username: Adirondak
Post Number: 3 Registered: Mar-08
Posted on xtream is a go! |
New member Username: Rvm
Post Number: 10 Registered: Mar-08
Posted on Thanks Paul. VS Ultra working for me again... |
Bronze Member Username: Arctick
Post Number: 31 Registered: Mar-07
Posted on Where is VS PVR7000 file?? It seems they always release PVR file late. |
Www.Desifta.com
Post Number: 1462 Registered: Oct-06
Posted on its because they have to make 2files Pvr7000 and Pvr7000II Same with PRO -PROII so it takes time |
Post Number: 522 Registered: Sep-06
Posted on Pro file dated 04/03/2008 is here ---> http://www.evilshare.com/e718ce60-5334-102b-a8ce-0007e90cfb90 |
Post Number: 523 Registered: Sep-06
Posted on Current pvr file dated 04/03/2008 is here ---> http://www.evilshare.com/bc542ec0-5336-102b-a8ce-0007e90cfb90 |
Silver Member Username: Dharm_ram
Post Number: 138 Registered: Dec-07
Posted on Thanks very much paul for putting up the link. VSU file works great |
Bronze Member Username: Feroz
New york,
New york
U s a
Post Number: 35 Registered: Aug-06
Posted on some of u said it works fine but wont say where u got d bin from? |
Post Number: 139 Registered: Nov-06
Posted on Thank yOu for the VSPRO file. |
Silver Member Username: Tigger_woods
DIAMOND VIP MEMBER,
DID I MENTIO...
VIP DIAMOND ...
Post Number: 500 Registered: Jun-07
Posted on Thanks Paul for the plat file...most sites where clogged. ![:-)](https://www.ecoustics.com/bbs/clipart/happy.gif) |
