hi all, I converted my clone pansat2500 - 2700 and now to puff version. I loaded the last puff bin and everything works great except for my channels. I did a powerscan on echo7 and 8 and all I get it's the sames 120 channels 2-3 times. How can I get all channels only once? What settings do I have to change ?
Echo8.10/Ku : LNB Type ; standard Lnb local-freq. ; 11250 22kHz ; off Diseqc ; off Legacy SW ; None Skew ; -45 TP ; [1] 12224 V20.000 Positionner Setting ; Disable Satellite Scan All Level ; 77% Quality ; 0%
I have a Dish500 dish with 2 lnbs. When I put TP to [2]12239 H 20.000, quality goes to 92%. What's wrong on my settings. Thanks
Abe: Echo8.10/Ku :..............Echo 7 LNB Type ; standard........try osc or dish pro in both Lnb local-freq. ; 11250....11250 22kHz ; off................off. Diseqc ; off or 2.......... 1 Legacy SW ; None........... 2 Skew ; -45................. -45 TP ; [1] 12224 V20.000..... 12239 Positionner Setting ; Disable/Disable Satellite Scan All......... All
Do Echo 7 first with a Blind scan and 110 totally unrecognised. Use Echo 7 setting as provided above on the right. Then disable Echo 7 and do echo 8.1 using those setting with disEqc switch off or set to 2. For future, please remember, that when you have working system, you write down your settings and keep them avaialble for rescan.
Nalin: If I might make a suggestion... When you do tables, use the courier font like this:
Because it is non proportional the columns will come out correctly, just the way you see them in the editor and your tables will look much tidier. Htiek
