Hi, i have a pansat 2500 converted to 2700, i had loaded the 250 bin as always do with all, and i dont get any channel, NOTHING! It says no program found when i make the scan. Anyone know what can i do? i`ll appreciate your help, thanks.
do a factory reset then load the factory bin and then the latest bin and then check ur settings and do a blind scan i did the same thing and i worked perfectly fine!!
