Viewsat Extreme Problem
Username: Baig_a
Toronto, ON Canada
Post Number: 17
Hi, Can anyone help me with a problem i'm having with my extreme? I downloaded and installed the latest file and it was working fine for the whole day but an hour ago it says searching channel. I'm getting th S but there is no Q. When i go into the antenna setup and change the tp frequency the Q does not stay steady. It keeps on jumping from 0 to 85 and back.
Anyone know what to do? You think its a problem with my switch? Or maybe show on the dish?
Thanks for the help.
Username: Madflea168
Post Number: 149
if there is the problem with the switch, try to run the cable direct from the lnb to your box.
is there any block to the antenna?
I had the problem with the tree branches brushing the dish once.
