Sonicview sv-4000 or Viewsat Ultra
Username: G_train
I have been reading alot of reviews stating that the sonicview has better picture. Is this true?
Could someone give me some pro/cons of these 2? I know the viewsat is more popular, but is it better?
And #1 thing...how is the sonicview support? Are bins released at the same time as for viewsat, faster or slower?
Thank You
Username: Djibo
Post Number: 25
Rob I bought my Sonicview yesterday, and the picture quality is really excellent. Downloading the bin is really easy whih the USB key ... For the support frequency I think is at least as viewsat. The only negative think I've noticed is the quality of the guide, really a poor information ...
regards
Username: Saqeeb9000
Post Number: 1415
Rob buy sonicview..b.c lots of people had problems loading the bin's with usb.. never heard any problem from sonic view..
+ sonic view always get files before viewsat..
Username: Scabz
Knoxville, Tn Us
Post Number: 260
I have a brand new ultra but a few days ago I bought an nfusion. Why not pay a few bucks more for something better. At least I have a backup reciever now.
Post Number: 1416
i have nfusion too...don't know why people are scared to buy nfusion...
i say if we are all stealing signal why don't we go to jail at same tima
Username: Scabz
Knoxville, Tn Us
Post Number: 261
Yeah maybe we can all meet up one day.
Username: G_train
So sonicview is recommended.
Now what is this nfusion. I read about it a little and it seems to connect to the internet and updates itself? How good is support?
lol..you guys are making it seem like it is "more" illegal than the other receivers...
Post Number: 1420
Great nfusion support: [link removed]
If you have another receiver, you can just take the old out and install the nfusion, just need to go to settings and configure it.
It supports Disec and SW21 switches.
It has a great picture
It connects to the Internet and retrieves all information
It has a great EPG
While it lasts, its one of the best TV experiencies I have had compared to viewsat, co olsat and Pansat
Aside of the concerns of being tracked by the IP address, there is no problem, I advice it.
Post Number: 1421
sada
Post Number: 1376
Posted on Saturday, January 05, 2008 - 05:28 pm:
[link removed]
sada
Post Number: 1377
Posted on Saturday, January 05, 2008 - 05:38 pm:
kels
Username: Kels
Post Number: 15
Posted on Saturday, January 05, 2008 - 05:45 pm:
thanks sada. that was excellent however he doesn't mention the hooking up the receiver via ethernet. I know how you would do it but once you plug in the cable at both the reciever and the computer....then what.
again...excellent link!
thanks
Ash
Username: Ash64
Post Number: 64
Posted on Saturday, January 05, 2008 - 06:01 pm:
gosh...TINA.. u really are ...........
sada
Post Number: 1384
Posted on Saturday, January 05, 2008 - 06:39 pm:
basically u just plug in network cable to any of the port on your wireless router and the other end goes on back of rec... it will automatically detect intenet connection.. u need network cable .. cost $ 10 .. same cable as you use on modem to comp (white cable).. after that u will see option on ur rec remote menu,ins internet ..wher u can see ur ip adress current sw version ..and by clicking on update u can update ur rec.. u don't need to unplug ur rec or anything. as long as ur internet is connected ur rec will work..
if ur rec is far away from wireless router . u need to buy a netgear cost about $ 50.. and u can just plug in to socket and the other wire goes to tv. so netgear detects internet from ur wireless router.. only if ur router is in some other room or else.. hope it helps.
ramiro gonzo
Username: Mdl97
Post Number: 72
Posted on Saturday, January 05, 2008 - 06:52 pm:
okay how much can i expect to spend on another viewsat extreme.i dont wanna get ripped off.assuming ill order it online.
kels
Username: Kels
Post Number: 16
Posted on Saturday, January 05, 2008 - 07:12 pm:
sada,
thanks very much...that helps alot. I would have to get the netgear as my tv is downstairs but the wireless router is upstairs. I'm assuming I can get it on ebay just as I would the nfusion receiver itself.
thanks for the info again...top notch!
