New member Username: Raceman24_1999Post Number: 2 Registered: Aug-07 | hey what would be the splitter to use so i can hook up dish and bev together? i have sonicview 1000... |
Platinum Member Username: LklivesPost Number: 12071 Registered: Jan-06 | They are NOT splitters...they are called "switches"...they combine the signals and switch them , they do NOT "split" them ...like a splitter for 2 TV's... use any disque switch that cost $4-5...keep a few spares...and weatherproof them in tupperware or inside the attic or wherever... The best are Spauns or chieta's which can be very expensive and really not needed.. |
New member Username: Raceman24_1999Post Number: 3 Registered: Aug-07 | you are right iam sorry i know that ..one satellite has a dish pro and the other is a older dual head....what would work for me |
New member Username: Raceman24_1999Post Number: 4 Registered: Aug-07 | ? |
Gold Member Username: NydasPost Number: 3799 Registered: Jun-06 | "older dual head" use it for Bev at 91 degrees. One output of this goes to Port 3 of one DisEqC switch,and the other output goes to Port 3 of second DisEqC switch. "one satellite has a dish pro". Use for 119W and 110W. One output goes to a one to two splitter and the two outputs of the splitter go to Port 1 of each of the two DisEqC switches. The other output goes to another one to two splitter and the two outputs of the splitter go to Port 2 of each of the two DiseqC switches. The output of the first DisEqC switch goes to one receiver and the output of the second DisEqC switch goes to the other receiver. The DisEqC switches mentioned above are 4 to 1 type and the 4th port will be left bare. In software, set up Echo 7 (119W) as Port 1, Echo 8.1 (110W) as Port 2 and Nimiq 91W as port 3. Scan all 6 settings (3 in each receiver). There are people in this forum who will not reply till I have posted and then they will start abusing me and you. It is their habit. Best of luck. |
Silver Member Username: Silver1123Mexico, DF Mexico Post Number: 227 Registered: Jul-07 | Nalin, have you used the "loop" output on a cool*sat? I have a cool*sat 5000 and a Dish 811 with a valid subscription, as a backup. Frequently,I have to unhook the cool*sat to hook the dish reciever in order for it to get updates. I have a single LNB, so switches dont work. So, I think on hooking the loop output to the sat in. You think its safe? I am worried about the current output-. Thanks |
Platinum Member Username: LklivesPost Number: 12113 Registered: Jan-06 | nalin doesn't even own a receiver...nevermind a coo*lsat..and she has no clue about the "loop" output...I will be interested in her reply about this...I know it will NOT help U or give U a straight answer..but U asked her, so I'm out.. |
Platinum Member Username: LklivesPost Number: 12114 Registered: Jan-06 | nalin doesn't even own a receiver...nevermind a coo*lsat..and she has no clue about the "loop" output...I will be interested in her reply about this...I guarantee it will be a copy/paste or the same as what I said...I know it will NOT help U or give U a straight answer..but U asked her, so I'm out.. |
Gold Member Username: Crazy_greekPost Number: 1143 Registered: Jul-06 | Hey,juan There is no need to disconnect your FTA receiver in order to connect your Dish receiver. All you need is a A/B switch. One receiver to A other to B. Either way you choose is safe. |
Silver Member Username: Silver1123Mexico, DF Mexico Post Number: 228 Registered: Jul-07 | thanks kevin, I'll do that. |
Gold Member Username: NydasPost Number: 3805 Registered: Jun-06 | juan Cavazos : What LK is telling you is that, she read my post of the use of two switches and splitter, could not fault it, and having got the opportunity of masking it, she came out with two posts about a different subject, deliberately presumed that I would not know about it and tried to both belittle me and to mask my post. Bravo LK, very well done. You have done it a thousand times and are past master at it. |
Platinum Member Username: LklivesPost Number: 12123 Registered: Jan-06 | nalin...U never even replied to the question here, from juan....Kavin answered it, cause U had NO clue!....LMAO so don't boast and take credit for Kavins, good answer... |
Gold Member Username: NydasPost Number: 3806 Registered: Jun-06 | LK: You are the one who specialises in robbing threads. You had nearly a day to answer roy mercer. He even posted a second ?. all you had said was information even the FTA novices know. Then juan Cavazos asked. You had your answer withing 20 minutes, saying I did not know about something as trivial as is available in almost all receivers. Before I even saw the question Kevin had replied and juan Cavazos was satisfied. There was no room nor any need for me to answer. Note that the question from juan Cavazos was directed to me. But as usual, as soon as somebody tries to look to me for answers you have to butt in. Now keep your butt out, when questions are directed to another individual. It is quite clear from all this that the person who started this thread did not get a satisfactory answer from the great LK, the pretendor to the non-existent throne. So LK, you have turned out to be the ignorant person, not me. |
Platinum Member Username: LklivesPost Number: 12133 Registered: Jan-06 | all I can say is , U are talking in riddles and are a complete WACKO... U were asked a question directly...and were here online at the time...and NEVER replied...instead U waited for kavin to answer cause u didn't know the answer... U did exactly as I thought U would do...I never did answer, because the question was directed AT you, not me!....but U chose to NOT reply due to your lack of FTA knowledge.. |
Gold Member Username: NydasPost Number: 3807 Registered: Jun-06 | Lk: You shine out as a double idiot in this thread. first becasue you could not and did not answer any of the two questions posted. Second because you do not even understand that of all your posts is this thread, there is no answer and you still want to criticise the person who gave the correct answer. Get lost, you stupid eccentric old girl. September 17, 2007 - 07:24 pm: Question by roy mercer September 17, 2007 - 08:14 pm: Incomplete answer by LK September 17, 2007 - 08:33 pm: follow up Question by roy mercer Over 19 hours later September 18, 2007 - 03:56 pm. No reply till this time A ? mark by roy mercer Why no answer by LK? Because he did not know the answer. September 18, 2007 - 04:26 pm: Full answer by Nalin Nyda September 18, 2007 - 04:56 pm: A slightly related question by juan Cavazos Question is addressed to Nalin. September 18, 2007 - 05:26 pm } Post by LK '" trying to discredit Nalin, saying Nalin does not know. September 18, 2007 - 05:27 pm: } Repeat post of the same by LK. September 18, 2007 - 06:01 pm: Satisfactory answer by Kevin Reno. September 18, 2007 - 06:40 pm:- Answer accepted by juan Cavazos September 18, 2007 - 11:18 pm '" Comment address to LK by Nalin Nyda |
Silver Member Username: Silver1123Mexico, DF Mexico Post Number: 235 Registered: Jul-07 | Guys, just to let you know that the A/B Switch did work, channels were operating great depending on the A or B setting, but I took it off since a smell of burnt cable started to como out of it. Could it have been because of the electricity that goes from the recievers to the LNB? |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1458 Registered: Oct-06 | Burning will be at the back of your receiver Yo put it in the wrong place |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 3156 Registered: Nov-06 | http://i4.tinypic.com/4pv97wg.jpg Here's a good remote controlled a/b switch. |
