Loading bin file with a usb to rs232 cable
Username: Msand951
Riverside, Ca Usa
Post Number: 13
Another problem which is more important is I have trouble loading the bin with the usb to rs232 cable. It worked fine with the cool 6000 but I cant get it to work with the pansat. Any tips would be great. I have a laptop thats why i need this usb cable. I have to go over to a friends house to do it with the regular cable and im getting tired of that. To get an idea of what im using . Its not an adapter that connects to the cable provided with the box. But a cable that is a usb to rs 232 to be more specific.
Username: Runnerguy
Pluto
Post Number: 533
What CABLE to use with various FTA makes?
Here is a list of the most popular receivers on the market and the cable needed to program them.
Ariza Ultra 400/500- Null
Astrovox 2600-Straight DB9
Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null
Co0lsat 4000 Plus-Null
Co0lsat 4000 Pro-Straight DB9
Cooltec-Null
Coship (All)-Null
Digiwave 6800/7000-Null
Digiwave Diamond-Straight DB9
Dreambox (All)-Null
Fortec lifetime-Straight DB9
Fortec Lifetime Ultra-Straight DB9
Lava 2600-Null
Max 2500-Null
****sat (All)-Straight DB9
Microroyal (All)-Null
Pansat 2300a/2500a and all clones-Straight DB9
Pansat 2700-Null
Pansat 3500-Null
Pansat 5000HC-Null(Also can program through USB)
Pantec/Multistar Max (All)-Null
Pantec/Multistar MS (All except MS1000)-Straight DB9
Pantec MX/Ultra-Straight DB9
Rex1-Null
Silver bullet/ST 1000/2000-Null
Skyview 500-Straight DB9
Spacestar DVB500-null
Stealth 2000a-Null
Ultrastar 5000-Null
Viewsat VS2000-Null
List of Popular Receivers Firmware Cable
NULL MODEM CABLE (Cross over )
* Ariza Ultra 400/500/700/750/800 & Extreme - Null modem cable
* Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II. MS1000, ,etc.)- Null cable
* Bluejay 1 & 2 -Null modem cable
* Buzz S2010F - Null modem cable
* Captive Works 1000s (CW500s,CW600s, CW600s Premium) - Null
* Co0lsat 4000 Plus-Null
* Cooltec ( Clones only ) - Null
* Coship (All)-Null
* Digiwave 6800/7000-Null
* Dreambox (All)-Null
* ExtremeView Magnam XV3300 - Null
* Koolsat/Sonicsat (clone) - Null
* Kusat Pro 2600a - Null
* Lava 2600-Null
* Max 2500-Null
* Microroyal (All)-Null
* Neusat SP6000 ( SP6000 Premium ) -Null (Also can program through USB)
* Orasat v5- Null
* Pansat 2700-Null
* Pansat 3500s/sd - Null Cables - (Also SD Memory Card)
* Pansat 5000HC-Null modem cable(Also can program through USB)
* Pantec/Multistar Max (All)=Null
* Rex1-Null
* Silver bullet/ST 1000/2000-Null
* Skyview RX600 - Null
* Spacestar DVB500-Null
* Stealth 2000 * Techsat - Null
* Ultrastar 5000-Null
* Viewsat VS200- NULL -------------------------------------------------------------------------------- -------------------------------------------------------------------- STRAIGHT THROUGH CABLE
Astrovox 2600-Straight through DB9
Co0lsat 4000 Pro/5000Pro/5000Platinum/6000Premium-Straight DB9
Cooltec ( Non Clone ) -Sraight through DB9
Fortec lifetime-Straight through DB9
Fortec Lifetime Ultra-Straight through DB9
lava 3200- straight through db9
Megasat (All)-Straight through DB9
Pansat 1500a/2300a/2500a and all clones-Straight DB9
Pantec/Multistar MS (All except MS1000)-Straight through DB9
Pantec MX/Ultra-Straight through DB9 Skyview 500-Straight through DB9 Andy
Username: Silver1123
Mexico, DF Mexico
Post Number: 70
It depends on the cable. Go to a radio shack store and look for cables and adapters, specially the USB to serial adapter.
Username: Lklives
Post Number: 11263
This is a common serious problem for many people...some puters and receivers simply will NOT accept these various adapters and drivers...Most FTA receivers were made for SERIAL port computers, NOT USB ports...thats why I always suggest a "USB READY" receiver like a sonicview 4000 or the VS Ultra..plus using a USB stick, there is no need to disconnect cables and move receiver room to room just to upload a file...
For U who are stuck with cable only FTA receivers, U have 2 choices...
1...buy an older cheap computer that has SERIAL ports..this is probalygoing to be cheaper in the long run than option #2...its surely much less aggravating!
2...go to radio shack and keep buying adpters , and hope eventually U will get one that is compatable with your receiver and computer...there is NO standard one that is guaranteed to work...its a hit or miss thing...
Username: Laurad
Post Number: 9
Does anyone have the repair for a 2500A Pansat. I can not download the new bin number. I have gone thru all the info and can not find a repair to clean the 2500A of its old bin numbers.
Thanks
Username: Kingusama
Post Number: 251
visit www.ftasolutions.blogspot.com!!
