Viewsat Ultra ?????
Username: Gigolo72
Post Number: 56
Just bought brand new viewsat ultra.
what are the steps required to get this baby up and running for dishnet ?? what do I need to load in to get it going? if anybody can please guide me step by step ??
thanks.
Username: Mc_sunny
Post Number: 962
Viewsat 2000 Ultra Setup Guide Using Serial Cable (NULL)/USB
A. Loading your BIN using Null cable:
Connect serial cable (NULL) to PC>STB
Open up Loader of choice (PVR-Loader 1.1 or Loader2)
Click on Tool>Configuration>Com port (Default is com 1)
Click on Open File
Click on PC>STB (Notice the progression bar in loader)
Wait for Loader say Completed. Then on box LCD front panel screen say I.N.S.T>END>0000 or until clock count to 0.001
IT IS VERRY IMPORTANT. DO NOT TURN THE POWER OFF TO SOON
Turn the power OFF in front and then back switch
Connect all the cables to your box/TV
Turn the power ON from the front and back switch
Press Menu key
Select Installation and press OK
Select Antenna Setup and press OK
Select your Sat.
Here if you have a DISEqC switch enter the port #, Motor or Legacy SW
No LNB Type need to select (from new, you have only two selection Standard and Universal). STB will select your LNB Automatic
Press Exit and select Yes for saving the settings
Your back to Antenna Setup screen
Here you have Three choices:
1. Channel Scan
2. Auto Scan
3. Blind Scan
Select Auto Scan
Press OK
You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options:
1. Search option
2. Network search
3. Scan Start
You don't change nothing, go down and select Scan Start and press OK
You do this for all the Birds (Sat.) you have
Wait for Autoroll and watch TV
J. Loading your BIN using USB Jump Drive
Press Menu key
Select your Sat.
1. Channel Scan
2. Auto Scan
3. Blind Scan
Select Auto Scan
Press OK
1. Search option
2. Network search
3. Scan Start
Now its time to download you BIN
Insert the Memory Stick in your PC and transfer the bin in. Than insert in your STB and in the Main Menu select System information and press OK
Select Receiver Upgrade and press OK
Go down to the bottom of the window, select USB and press OK
A new window opens with some Korean files, years, etc.
In the bottom of the window, it is your bin select and press OK
VERY IMPORTANT. DO NOT TURN THE POWER OFF
After you load the bin, the STB will reboot automatic
Username: Mc_sunny
Post Number: 963
Here is the latest bin for Viewsat Ultra with New Features PFTAUSW-070104U, If u have USB, it is easy and faster to load the bin into ur recevier
New Bin
Here...http://www.dssrookie.com/forums/b-font-color-cd2626-vs-ultra-files-font-b/ultra- new-features-pftausw-070104u-115540.html
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 794
Spoon feeding.lol I did my research before I bought my receivers.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 271
satscanner,
I agree with you 100%. When I got my receiver I had spent WEEKS reading all I could find on the topic. It took me 30 min of getting that pansat to get it working. I just got my viewsat a few weeks ago also. By the time it got here I had printed out the instructions on how to load it, the users mauual, and had all the files-bins already on the laptop ready to load it. Within 15 min of getting home with it I was watching tv. I just won on ebay a HF ham radio. I have downloaded the users manual, service manual, joined every yahoo group or forum, and every "how to" I can find to get ready to use it. Mabee its just me but I think its smarter to use your time you have to wait for the to receive the item to learn how to use a new piece than wait untell it arrived and expect someone to show you the easiest way to just get it working 1/2 way.
But thats just me
