New member Username: Legend99Post Number: 2 Registered: Dec-06 | I am stumped! I have tried to read as much as I can but have not been able to find what I am looking for, so I ask for help. Just got a new Viewsat Ultra and am trying to hook it up with my existing setup. I have tried different combinations and so far this is the one that works the best, the problem is that I am still not getting a weak signal on the Horizontal channels. Having said that, last night when I did this setup all channels were coming in with signals over 70. Tonight on the 119 Sat i get on some channels less than 5. From the diagram you can see my setup, am I doing something wrong? need to add something? Remove something? Thanks ![]() |
Silver Member Username: SatscannerNDS Laboratory Post Number: 551 Registered: Nov-06 | First I would change the dpplus lnb for dp,get rid of the splitters and diseq switch and connect the lnb's directly to the dp44,then to your receivers. |
Gold Member Username: LklivesPost Number: 6673 Registered: Jan-06 | why NOT LNB's directly to the DPP44, then receivers?...why the signal "splitters" and disque? READ this! http://www.sadoun.com/Sat/Products/Dishnetwork/Switches/DPP44-switch.htm and if your setup worked fine last nite but NOT tonite, then recheck cable connections, dish alignment, cables etc..receiver antenna/dish LNB settings...and different transponders get different strengths ... And NEVER disconnect any cable or switch when receivers are powered..and may need to keep 2 receivers ON always for LNB power too!...DPP LNB's suck! |
Silver Member Username: SatscannerNDS Laboratory Post Number: 552 Registered: Nov-06 | That's what I said . |
Gold Member Username: LklivesPost Number: 6674 Registered: Jan-06 | Your post was NOT posted or seen while I was looking and reading at sadoun to get the link for him about his DPP44 w power adapter switch..he can keep the DPP LNB's.. |
Silver Member Username: SatscannerNDS Laboratory Post Number: 554 Registered: Nov-06 | I know ,I just slid it in to fire you up.lol.But I would still ditch the dpplus though ,reg dp will give less problems,and there inexpensive,so my mess with it,even though it will work,just another switch to cause problems."Simple is Best". |
New member Username: Legend99Post Number: 3 Registered: Dec-06 | Tried removing the splitters and the Disq switches, everything works, except 91, which I connected on port #4 of the DPP44 switch. |
Silver Member Username: SatscannerThe Doghouse Post Number: 562 Registered: Nov-06 | Check your ant settings,and connect the coax from 91 directly to the receiver and test for signal.Somesimes rocking the channel up/dn and on /off help trip the switch,also recheck your connection's. |
New member Username: LovefreesatMontreal, Qc Canada Post Number: 1 Registered: Jan-07 | hey guys im new in here and i kinda GOT A PROBE WITH MY VIEW SAT ITS NOT SHOWING ANYTHING I USE TO POWER IT OFF WHEN IT FREEZES BUT NOW I CANT GET ANYTHING SO IF YOU GUYS HAVE ANY NEW INFO PLEASE HELP ME UP THANX |
Gold Member Username: PrfrmnjPost Number: 1105 Registered: Oct-05 | Brian - What's your setup? What's your system configuration? What type of LNB's do you have? Are you running a switch? What's the latest .PGM file you flashed it with? Need all of this information to be able to help you out. |
Gold Member Username: LklivesPost Number: 6851 Registered: Jan-06 | brian..must be nice to just Hijack any thread U want...LMAO |
