This was the first time I ever used the satinfo file. When I went to scan the channels there was no onger a 8, 10 110 satallite but instead a 8,X 110W one with all Spanish stations. What the heck did I do??
Then I did another factory reset and reinstalled only the first two again. Once again I got about 150 channels that looked like they had all Spanish names so I didn't save them. Now I'm really getting worried. I'll try using an older file in the morning. This really seems like a whacky problem.
change your LNB settings. Make sure that your setings are the right one for your LNB. If it is Dish Pro: ocs-dp. If it is Legacy, Legacy Twin LNB1, etc.. make sure you have the proper settings for the LNB and you will get your channels back.
