I have a Lava 3200 it is Pansat 2500A Clone. It works fine as and when I put in the new keys.
But lately the picture stops and pauses a lot.. lots of pixels (square blocks on the screen that do not update). channel navigation is slow... and since I have to enter the keys manually means my Autoroll also does not work.
Seems like it is time for a new bin. I checked DSS tester and was not sure which is good working one..
So I need some inputs on a working bin for a Pansat2500A clone. I dont want to change my existing bin and end with a non working one and totally lose what every I can atleat see now..
ONLY one is 286T, that works the best...U may have to clean some corruption off the receiver by uploading the factory bin a few times first..or wait for a new bin to be released which will be posted everywhere..U may have some cable /connection issues as well..the receiver is a POS, so be happy that it works..
Viewsat Ultra, Extremeview Magnum are both good..read the reviews posted at Reputable Dss sites!...USB stick is nice feature on Ultra...Extremeview's ability to use cards is nice feature of that..
