Username: Poonam008 Post Number: 6 Registered: Nov-06
Thursday, December 21, 2006 - 23:55 GMT Hi..I'm kind of new here. I have Fortec lifetime classic na receiver and i'm getting echo 3 and echo 7. I have installed a sat disc after few months and i'm not getting Zee TV in it. So can somebody please tell me that are you getting zee tv if yes than it's name has changed or what? Thanks in advance.
Username: Ustaad_hc Post Number: 169 Registered: Oct-06
Friday, December 22, 2006 - 00:42 GMT yes ZEE TV running fine same name and TP is 12599.you just do the blind scan or power scan whatever. you will get that channel...........
Username: Poonam008 Post Number: 7 Registered: Nov-06
Friday, December 22, 2006 - 01:10 GMT Thanks a lot.
Username: Poonam008 Post Number: 9 Registered: Nov-06
Saturday, December 23, 2006 - 18:39 GMT I'm not having TP-12599 in list. How do i scan it? please give me advice and details. Thank you very much.
Username: Lklives Post Number: 6556 Registered: Jan-06
Saturday, December 23, 2006 - 19:28 GMT add the TP then...add/edit sats.. if using bin 286T, and correctly aligned dish,and correct receiver settings, then U would be getting the TP with a blind scan..
