You'll need a loader which you can get it from any reputable fta site, except here. Anyway, check out dsscommunity and you should be able to find it there in the file section. You have to register but I believe it's free. There should also be instructions there to find. check here.... http://www.dssrookie.com/forums/sitemap/f-111.html
Nasreen, Instead of posting in 5 different threads, why don't you read this one, get the bin discussed and load it to your Fortec? Then you won't have to manually enter them anymore.
