Boyce, please help!
Username: Friday
Mississauga, Ontario Canada
Hi Boyce, now I know you are chinese. Please help me (a chinese girl!).
Do you have chinese channel ruuning? Mine doesn't work since this morning. Everything else works fine (including PPV and all other america networks). I don't think it is a key problem. I try to re-scan the dish, but no multi-cultural channels coming up on the list anymore.
I am using bin273, no problem since March. Not sure what happened!
My parents are really bored without chinese TV, please help!
Username: Boyce
Post Number: 48
If other program work, then that is not the key problem, before scan channel for 121, make sure you get the signal, quality from 121 LNB frist, check switch, or hook the cable from the box direct to the 121 LNB (bypass the sw21).
Username: Friday
I do have the 22KHz switch. Will it be broken? I have signals with the switch on and off. But in either case, the scan doesn't give me the 121 channels.
Username: Boyce
Post Number: 50
Please bypass the sw21(22KHz switch), hook the cable FROM 121 LNB TO your box. I told you before, it may be a dead switch.
Username: Lklives
Post Number: 2295
sw21 is NOT a 22khz switch...they are completely diffrent and for different purposes and LNB's and receivers..
Username: Boyce
Post Number: 53
LK you right, my mistake, sw21 is not 22khz switch.
