Orasat Manual Key Entry
Username: Lklives
Post Number: 1814
ON YOUR REMOTE CONTROL PRESS 6969
A SCREEN APPEARS NAMED CODE EDIT
ON YOUR REMOTE CONTROL PRESS THE BLUE BUTTON (MARKED AS SLEEP)
PRESS THE DOWN BUTTON FOUR TIMES TO HIGHLIGHT LINE 5
PRESS THE OK BUTTON ON THE REMOTE CONTROL AND AN ON-SCREEN KEYBOARD WILL APPEAR
YOU WILL ENTER THE NEW CODE NUMBERS BY USING THE UP/DOWN AND LEFT/RIGHT BUTTONS. YOU WILL PRESS OK ON THE DESIRED NUMBER OR LETTER TO SELECT IT.
USING THE ON-SCREEN KEYBOARD AND YOUR REMOTE CONTROL ENTER:
10 XX XX XX XX XX XX XX XX THEN GO TO OK ON THE ON-SCREEN KEYBOARD AND PRESS OK ON THE REMOTE CONTROL
PRESS THE DOWN BUTTON JUST ONCE TO GO TO LINE 6
20 XX XX XX XX XX XX XX XX THEN GO TO OK ON THE ON-SCREEN KEYBOARD AND PRESS OK ON THE REMOTE CONTROL
PRESS EXIT ON YOUR REMOTE CONTROL
YOUR FINISHED. IF YOU FOLLOWED THE INSTRUCTIONS CORRECTLY EVERYTHING SHOULD BE BACK UP AND RUNNING
