Thread: Help on my panasonic dvd |
New member Username: Lambytd
Post Number: 1 Registered: Sep-08
| Posted on Wednesday, September 17, 2008 - 11:04 am: |
Hi there i have a panasonic dvd and t.v my dvd player is sa-pt450 and i would like to put camcorder video's on to a disc and play them on my t.v i have tried this dvd+r and dvd-r but it won't play them could you tell me if there is any reason for this thanks mark. |
Relevant Product Info
Gold Member Username: Samijubal
Post Number: 3929 Registered: Jul-04
| Posted on Wednesday, September 17, 2008 - 05:05 pm: |
What are you using to record to DVD-R? |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 3480 Registered: Oct-06
| Posted on Wednesday, September 17, 2008 - 10:41 pm: |
When yo record on DVD-r yo must finalize disc to become a playable DVD disc |
Post Number: 2 Registered: Sep-08
| Posted on Thursday, September 18, 2008 - 07:20 am: |
What i have done is i have downloaded a video from my camcorder to my p.c and then i have put it on to a disc pretty sure it's gone on to the disc but it won't play on my cd player it just say's on my t.v that it is not compatable. |
Bronze Member Username: Levelzero
Post Number: 66 Registered: Aug-07
| Posted on Thursday, September 18, 2008 - 11:30 am: |
Is your dvd burning software set to be compatible with your DVD player? Be sure the region code from the software is compatible with the dvd player you have. For instance, if your burning software is set to NTSC (Region 1 - US), but your dvd player will only play PAL then you will continue having problems. See if you can set your burning software to be region free. |
Post Number: 3930 Registered: Jul-04
| Posted on Thursday, September 18, 2008 - 04:02 pm: |
All burn software is region free. I'd guess the burn format isn't compatible with the player. The DVD standard is MPEG 2. I don't deal with camcorders and can't really give any more help. |
Nottingham England
Post Number: 3 Registered: Sep-08
| Posted on Friday, September 19, 2008 - 01:24 pm: |
I'll give it a try thanks for your help Mark. |
