Thread: Burn a DVD with dvdcoach playable on my DVD player |
New member Username: Lelangard
France
Post Number: 1 Registered: Aug-08
| Posted on Monday, August 04, 2008 - 08:20 am: |
Hello I'm using dvdcoach express from kibisoft (http://www.kibisoft.com/)to convert my avi to DVD. The problem is that I can read only 2 dvd out of 3 on DVD home player.I dont understand why. For me the problem is not dvdcoach which is a reliable software specialized in converting and burning all formats of video to DVD but more from my home DVD player !! If somebody using dvdcoach express has an idea, pease let me know |
Relevant Product Info
Bronze Member Username: Levelzero
Post Number: 55 Registered: Aug-07
| Posted on Monday, August 04, 2008 - 03:32 pm: |
What brand blank DVDs are you using? Have you tried testing the "bad" dvds on other dvd players? Try Verbatims if you haven't yet. |
New member Username: Francinemau
| Posted on Monday, August 04, 2008 - 06:44 pm: |
Hi If you can read 2 videos on your pc, I don't think it s dvdcoach fault. it s more your dvd player. Which speed do you burn ? What kind of media do you use ? |
Post Number: 56 Registered: Aug-07
| Posted on Tuesday, August 05, 2008 - 09:53 am: |
It appears that you should first try burning at a lower speed. If your settings are set to automatic and that isn't working try lowering the speed to half of the disk's rating. This question came up on afterdawn's website. You may want to try this forum and looking at theirs for great information. http://forums.afterdawn.com/thread_view.cfm/674909 |
