KidA Unregistered guest | Looking for suggestions on a good pair of wall hanging rear speakers. Room is 24x12. HK AVR7200 receiver with MA S6 and SLCR speakers. HSU STF-3 sub. Looking to spend less than $500 on the rear speakers so the SFXs are out. Not sure if I want dipoles. I saw a pair of Boston Acoustics Bravos. They are shaped like a 1/4 cylinder and fit where 2 walls meet. Has anyone auditioned these? Also, has anyone been on a US site that carries the MA BFX speakers? How much are they? Opinions would be greatly appreciated. |
New member Username: EdisonPost Number: 155 Registered: 12-2003 | Might want to go with MA model to match the sound. |
Stevecml Unregistered guest | Triangle has a nice slim wall hanging speaker with the hole already cut into the back of the speaker(can hang it like a picture). Comes in cherry wood finish. |
New member Username: RailbaitPost Number: 6 Registered: 12-2003 | You may want to try a pair of these Magnepans. They have a free trial period. They are about to start production, so it may take two months or so to get. I am on the waiting list. http://www.soundstage.com/revequip/magnepan_mmgw_mmgc.htm |
KidA Unregistered guest | Thanks for all the info. Im intrigued by the Magnepans. Will my HK 7200 be ok to drive them? |
KidA Unregistered guest | James Lee, I cant find the MA BFXs anywhere. Have you seen them? |
New member Username: RailbaitPost Number: 7 Registered: 12-2003 | That receiver is very powerful, but check the manual to be sure. I didn't see any mention about 4 ohm speakers in a quick look online at the manual, so you may have to contact Harmon for that info. |
