Sub for Take 5.2 and AVR 330 receiver
I found a great deal on the Take 5.2 without a sub. I need a good sub ($350 or less) to go with these speakers and the H/K AVR 330 receiver.
Your opinions are appreciated.
Thanks.
P.S. If you recommend a sub, please also recommend a place to buy it (either a big chain or online) if you can.
Derek
JBLs are easy to find (Best Buy).
If you can hunt one down Mission makes some good under $350 subs.
www.partsexpress.com sells some good sub kits.
I forgot to mention that my room is 16x20 (16x16 listening area) with 17' ceilings.
Is the Energy s8.2 a good sub?
