Which amp for Tannoy F1 custom?
Username: Spirovious
Hi,
I own HT setup with ONK & F1 combo.I need to get seperate amp for CD listening.I have 2 options,
Nad or Rotel
Nad 326bee is reveiwed well & old Rotel-04 is recommended for F1.For serious listeng from classical to movies(occassionally fast tracks) ,which amp will be better?any other models also welcomed.
Current source can be oppo980 DVDp & may upgrade CDp later.
Pls guide,
Thanks.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2653
I think either one would be just fine. I've driven my Tannoys before with a Rotel RA-02. The combination sounded great. I prefer Rotel over NAD, but that's just me.
Can you focus on F1 + CA340(540)?
Username: Nuck
Post Number: 12617
Are you taking the Tannoys out of the HT and adding a cdp and power source, or mixing it up?
I will be using switch to get either output.
I m cofused with amp matching.
