Velodyne 8" Minivee vs. Martin Logan 10" Dynamo
Username: Daveappen
Hey guys, I need some help in deciding between the following two subs:
Velodyne 8" Minivee
My HT area only allows for a small sub and I'm able to get a good price on both. I'm also looking at the Def Tech supercubes, but I can't get as good a price/deal on these. For those that have any experience with either sub, could you give your feedback? (primarily comparing the two subs)....
Thanks in advance.
Username: Arande2
Rattle your ... Missouri
Post Number: 2923
When I heard them, I just liked the Dynamo better.. but you should probably just dismiss it as bias towards the brand.
Username: Daveappen
What did you like better about the Dynamo? And why would you be brand biased?
