New member Username: Bruces10Tuscaloosa, AL USA Post Number: 5 Registered: Jan-07 | Please, help a guy out....after much delay, I am putting together a home theatre system which incorporates a new receiver (Yamaha RX-V659)to a subwoofer (JBL PB12) which I have had for a few years. I will be running the subwoofer cable through the walls and will need a run of approximately 38-40 ft. What brand/type cable would you recommend I use for this? Secondly, in the past, I had this subwoofer hooked up to an Onkyo TS-DX676 receiver using RCA dual (L & R) plugs to the Line Level In L & R connections. However, it appears that the Yamaha receiver (RX-V659) has only one place to accept a RCA plug-in. What type connection/cable would you recommend I use in this case? Thanks. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11876 Registered: May-04 | . Call these people; http://www.parts-express.com/ They will answer all your questions and suggest a cable in your price range. |
New member Username: Bruces10Tuscaloosa, AL USA Post Number: 6 Registered: Jan-07 | OK. Thanks for the advice, Jan. |
