I installed my new system last night, and I have a constant buzz in my center channel speaker. I swapped speakers, swapped wires, moved the speaker, and it still is only the center channel that is getting this distortion. Any suggestions?
Adam C
I hate that sort of thing, the only problem i can relate that too, having it at one stage myself in the living room system is a faulty cable, change the cables and make sure it doesnt come loose. I my situation it was because the scart cable with the audio outputs from the back of the tv wasnt, tightly fitted
It can also be related to several other factors like enviroment, and power. Make sure u keep the amp somewhere out of moisture etc... sorry i couldnt be any more help.
